Changing grind settings after replacing basket.
  • Changing grind settings after replacing basket.
    Ive just replaced my Silvia double basket with a Synesso double ridgless and noticed that Ive had to back off the grind by 3 - 4 clicks on the Rocky to maintain a good flow. Im just wondering if this seems right, would more coffee in the basket mean a longer pour time if the grind and tamp is the same?
    Re: Changing grind settings after replacing basket.
    Yes. More coffee = more resistance = longer pour. So with a larger basket (with the same hole area) you would need to loosen the grind.
