Left over beans
  • Left over beans
    I havent got round to building my own roaster of any form yet, so purchased a roasted sample pack from Beanbay about 3 weeks ago.
    According to the theory of threes roasted beans last around 3 weeks, and while I am still getting good aeropress coffees from them, I still have over 1/2 of my kilo of beans left (one pack entirely unopened).
    I will carry on using the beans until they become unpalatable, however I would like to know what everyone does with left-over beans? At the rate I am going, it could be another 2 months before I finished them.
    I guess when you have your own roaster, you can tune how much you roast each week to your average usage, and I will soon look to get either a popper or coretto going.
    Id rather not waste a lot of the beans that I will have leftover so does anyone have any suggestions for cooking, baking, etc, or do you just throw them away?
    Re: Left over beans
    Make up a batch of CP (Cold Press/Process) before they go stale. That way you get another 2-3 weeks of fresh beans.
    Java "Hhhmmm....Yummy CP!" phile
    Toys! I must have new toys!!!
      Re: Left over beans
      Did you see that I experimented with CP on my aeropress last night, or are you reading my mind?
      Will have to research here for a way to do a greater volume than the AP will allow
      Linn..."slightly freaked out by JP"...aen
        Re: Left over beans
        Just do a big jug and then filter it with a drip filter paper.
          Re: Left over beans
          Its the antennae that allow Java "the mind reading alien" to probe all CS members thoughts .. was that in the fine print when we signed up to this site? ;D ;D ;D
          As for before I started roasting my own needs (popcorn roaster) .. I use to freeze the beans. The image of the Bloom in the Kyocera thread
          http://coffeesnobs.com.au/YaBB.pl?num=1240128496/165#165
          was a batch of Coffeesnobs Espresso WOW that had been frozen three months prior, about 3 days post roast. .. read this post:
          http://coffeesnobs.com.au/YaBB.pl?num=1240128496/47#47
            Re: Left over beans
            Damn, au_d2 figured it out! Now Ill have to be more careful with them!
            Java " ;D " phile
              Re: Left over beans
              This is the sort of quality advice only given by a true CP er. The only other thing I can think of is to freeze them. (running for cover) ;D
                Re: Left over beans
                Great idea JP, but I only have the kyocera hand grinder. So at 14gms per grind I will have arms the size of the Governators by the time I finish (especially if I try to follow the theory of threes and get it done in 3 minutes).
                  Re: Left over beans
                  If I have beans more than about 4weeks old I grind em up and take em to work and brew the lot up on the dripolator for morning tea. Never any shortage of starters for free dripolator coffee and the Instant drinkers think it is a treat. I call it PR.
                    Re: Left over beans
                    Just to make sure of your measurements .. 14grms is if you fill the Kyocera level with the internal "wings". If you fill the whole chamber you will get 20grms (and if you heap it you can get 21grms) per grind.
                      Re: Left over beans
                      au_d2: That much at least was remembered from your very kind after sales service.
                        Re: Left over beans
                        You dont want a fine grind for making CP. It should be on the coarser side. I typically grind almost to what youd use in a (blech!) percolator. That will help the grinding go quicker.
                        Java "Hurray for CP!" phile
