Draining HX machine boiler
  • Draining HX machine boiler
    I am heading overseas on Tuesday for 3.5 months and my machine will not be used until I return. Is it a good idea to drain the boiler before I leave or should I just give it a really good flush when I return?
    If I should drain the boiler, is it just a matter of bringing machine up to temperature, drain water from brew head, then drain whatever is left from hot water dispenser? Thanks.
    Re: Draining HX machine boiler
    Originally posted by 1E292F3F34255C0 link=1252799275/0#0 date=1252799275
    .... is it just a matter of bringing machine up to temperature, drain water from brew head, then drain whatever is left from hot water dispenser? Thanks.
    Hi Buschy,
    I replied to your email, but it bounced back (seems to happen a bit with you  :-/). Do as you have suggested to drain the boiler and then give it a good flush on your return.
    Bon voyage!
      Excellent thanks! .
      Ill look into the email problem.
