Using a fridge water filter for a coffee machine??
  • Mischa
    Re: Using a fridge water filter for a coffee machine??
    thanks for the advice i wont worry with a fridge filter then lol
  • GregWormald
    A five micron filter will remove most of the larger sediment and (probably) the chlorine, so it is sure better than nothing.
    Unfortunately, this means the dissolved minerals will (likely) be untouched, so the scaling remains the same, and the smaller sediment, between 1 and 5 microns in diameter, gets through.
    It all depends on your water. I prefer the system I have now, a 1 micron carbon filter and an ion-exchange softener, especially with the reticulated water here.
  • Koffee_Kosmo
    Originally posted by 6C4852424940210 link=1256986305/0#0 date=1256986305
    Just wondering what people in the know think about using an inline water filter designed for a fridge (5micron) as opposed to using one designed for a coffee machine?? Are they the same thing?
    Should work if the correct filter is used
    Contact Bombora and they will be able to advice you
  • Mischa
    started a topic Using a fridge water filter for a coffee machine??
