how to run a coffee cart with no water supply in shop
  • how to run a coffee cart with no water supply in shop
    I have been looking around for a place to start my little business, today I seem to have find a little space that has enough foot traffic to support the business however when I spoke to the agent he said there is no water to the shop, he said he will consider a coffee cart business but even so I have to work out how to get water to the shop for the espresso machine, I thought of using distill water delivery service but what plumping requirement would I need for it, and there is that stainless steel water tank for storing water as well, advice from anyone truly appreciated.
    Re: how to run a coffee cart with no water supply in shop
    Originally posted by 787E66666E7968796E666A0B0 link=1257147234/0#0 date=1257147234
    Regardless of teh machine.. Washing and cleaning will also require Water and last but not least a DRAIN...
    Distilled water if you want crapy tasting coffee....
      Hi there summercrema. I presume your cart should have sink/pump and water storage installed. I have a mobile setup that the hose from my espresso machine just drops into a 20 ltr plastic water container.
      the internal pump of the machine draws from that. I use filtered tank water. 2 x 20ltr containers is ample for a couple hundred shots. Just remember to attach a very fine screen at the end of the hose in case any small particles get into the container. Specialist plumbing suppliers should be able to help. I have done it this way for about 5 years now no prob.
      good luck
        Hi Guys,
        Running of a tank is a bit risky, Youll find you chew through more pumps, sometimes quite costly. Just do one thing when running off a tank always use a one way valve. On the end of your braided hose thats in the tank screw on a one way valve, this will help prolong your pumps hard life.
        Ask at any plumbing store
        Im sure AM will jump in to tell you why! ;D
          Agree with that 9Bar. I did do that at the start but have been guilty of not having one on lately and you can hear the pump strain a bit when first turning the machine on to get it primed. Thanks for the reminder.
            Thanks everyone for the input, can someone suggest who can I contact for making a stainless steel water storage tank "food grade" , I think 200 to 300 litres should be enough for a week usage.
              Summercrema;
              Google coffee carts and you will get a few ideas example http://mvu.com.au/coffee-carts.html
              Remember this goes under food, so you will need a Council approval
              Anything we can help let us know.
              regards
              Renzo
                Originally posted by 2D2B33333B2C3D2C3B333F5E0 link=1257147234/5#5 date=1257675478
                Why do you only want to fill up once per week? There are poly tanks at around 100 litres which will be much cheaper (caravan accessory websites are the go). Also if you are intending to be busy then 300 liters in a week probably wont cut it.
                  If you want a stainless steel tank, made to measure, contact designer tanks in Rochester. They deliver to almost anywhere.
                  email Glenda: info@designertanks.com.au or 54841094.
                    Hi,
                    You can get a 12 or a 240V coffee cart pump and pair that with a food grade plastic water tank. You won't get through much water even when you need water at the sink so 100 litres is usually plenty. You could use a water bladder like the Plastimo bladders if you have a spot for it. Add a screen filter to your inlet line to the pump and maybe an accumulator tank if the pump is bigger that 8-10 litres per minute. That should give you a sweet set up!!
                      Originally posted by beccarivers View Post
                      Hi,
                      I hope ole he's still not trying to figure out that 'project' seven years on
