Originally posted by 61786E6463696C0D0 link=1266585169/14#14 date=1300142274
Im just not that Anal... :
Seriously, its coffee not a lifesaving medication or something that requires a microgram measurement to prevent explosion etc.
Ive been weighing for the last week and doing similar to Darkfalz except that Im mostly not changing the weight, just the grind as they age.
However as they get on a bit I find I do have to grind courser and add more beans because I cant go any finer without causing sloppy pucks and choking.
Im not that anal either lucinda.
Its just another way to do it, isnt hard and not much slower than my previous method.
Originally posted by 704140575C5D51340 link=1266585169/12#12 date=1266655596
My father came out of hospital only yesterday after some serious heart surgery couple weeks ago and the first thing he said to me yesterday was that he badly needed a good cup of coffee........lucky for me, I invited my parents tomorrow for dinner and coffee from my new machine.
I sure hope I can produce a good Rembrandt tomorrow !!
DIT TO I might go to a few extremes to set a base line and then it is all bucket chemistry. It is about being consistent without any impost, such that whacking out a cup and the odd sink shot; is still enjoyable.
Now if I was in the lead up to high level comp it may be different. But then a Great Barista should be able to flow with teh day and the product he is given. May take a shot or two but not much more.
When one concentrates on all teh infinite values and measurement, it is easy to loose site of teh cup and the intent of enjoyment.
Perfection is a Dream and the journey should be a joy to behold, not a frustrating slog.
Sorry to resurrect an old thread. Ive recently started weighing my beans and putting them into the hopper just before grinding. I am getting better consistency and much less waste. I think the beans stay fresher this way too. I find that the amount is proportional to the grind - with nice fresh roasted beans, I am using a grind setting of 16 and putting 18g of beans in there. If theyre a little older, 19g of beans at a setting of 15 and then to 20g at 14.
Ummm lucky for me I was not good at science but great at art.........
Getting there ever slowly.....I find that the more you read and the more research you find, the more i get confused.....
Originally posted by 1D2C2D3A31303C590 link=1266585169/10#10 date=1266649360
Good point AM about calibrating or adjusting the grinder........
Will look further into that.......I suspect that rather coffee is an art, I suspect over the past fortnight it is more of a science........
Na its an ART..
Just like medicine .. It is not an exact science and if only some knew just how much black magic went into it.. Well; enough said. 2 + 2 = 5 for great coffee
Not unlike many other things in life.. Many can read and talk the talk (Science) ... But few can walk the walk (it is an ART). Problem is that too many get them confused
Originally posted by 1631242B450 link=1266585169/7#7 date=1266640137
I grind only enough beans to make the coffee. I do not weight the coffee but do it by sight. Sometimes I get it wrong and have to much or to little but not enough to start weighing the coffee beans before I grind.
Same here...
Only time I would weigh... Is as part of a check or to work out how many shots to a Kg and thus adjust any costings.. Do it once and not bother again...
Unless trying to calibrate or adjust a grinder for a specific use..
What is wrong with you and why are you poll racists??!!! ;D ;D
Yeah, I have been looking at a few barista courses and might once I finish off my studies to do one of those ones during a Saturday in Melbourne.........
I know I may get some inconsistency but that is life. I maintain consistency with my dosing and tamping which gives me consistent taste.
Find a dose volume that worked in my machine. The 5 cent test was a part of this as was tasting!
Weigh that dose. It was 20 gm for the double basket. I never use the single as I only make doppio ristrettos.
Weigh each grind as beans so Im grinding until the grinder is empty.
Result, good coffee, some great coffee.
Notice that different beans have different densities so the weight doesnt correspond directly to the volume, and changing volumes is not what I want.
Find a scoop that holds the right volume of beans and use that instead of sticking to weight. Still grind one cup at a time.
Notice that some beans grind or tamp to different volumes despite the same volume of beans. Now I adjust the volume of beans depending on what I know about each single origin/blend. Result: great coffee most of the time.
Sometimes I think the coffee result depends on how I hold my tongue while making it. ;D
Guest replied
Re: Weighing your coffee
Originally posted by 4F7A77704458747D7D7E7E1B0 link=1266585169/4#4 date=1266612888
I reckon that if you have to weigh it, a coffee course would be very useful
couldnt agree more - consistent free dosing is the way to go. I should add that I learnt this at a Talk Coffee course!
I am yet to see baristi in competition weigh their beans and it doesnt happen in cafes either
I have to say that I was stunned to see NSW Champ Matt Perger find the time in his routine at the nationals to weigh ground coffee for his shots. That is definitely the exception and not the rule, and I certainly agree it wouldnt work in a retail environment.
As mentioned by Talk Coffee above and I agree, for my process at least, free dosing on a consistent basis is the way to go. I also find the need to adjust dose on a constant basis, as coffees age they require different handling.
My general approach to all things though is to try and use a process that would also work in a retail environment. Thats just what works for me!
