Coffee by the Numbers
  • Coffee by the Numbers
    When I was training for Organization & Methods many years ago I was taught that whatever can be measured can be controlled.
    That appealed to my accountant’s brain and now to my CS brain
    Some baristas seem to be able to produce great coffee without measuring much at all – they have it down to a fine art from loads of practice. We lesser mortals benefit from being able to repeat a shot by applying the same numbers that we’ve found reliable in the past. But do we get carried away with the numbers 8-)
    Such things as:
    Grind - depending on the bean, weather etc etc.
    Dose - More important than most newbies realize.
    Tamp – perhaps not as critical as we’ve been told.
    Extraction time – forget the seconds, watch the pour.
    Milk – the hand is not a reliable temperature gauge.
    So let’s sort them.
    Standards:
    Dose
    Tamp
    Milk Temperature
    Variables:
    Grind
    Extraction time
    I think this should open up a bucket of worms :
    Re: Coffee by the Numbers
    Add to ya variables......
    Bean
    roast level
    profile of roast
    age of roast
    You right though, for me, its coffee by numbers, I think its a common with most of us snobs, except AM ;D, its the process we love. I thought today actually......I wonder how many members coffeesnobs would have if all we had was super autos?? Not many, coffee would be aweful and boring!!!
    Warren
      Bean
      roast level
      profile of roast
      age of roast
      Youre right Warren - I meant to qualify my list as excluding roasting :
        yeah.....the problem is, someone roasts it ;D so these factors apply whether you want them to or not ;D
        "buggar" i hear you say
          Originally posted by 7571574E4E4B54434C220 link=1270187329/3#3 date=1270195187
          yeah.....the problem is, someone roasts it Grin so these factors apply whether you want them to or not Grin
          Yes, but the only control I have over that, is who does the roasting - so it is not really a variable in my equation
          For each batch of beans my list still applies :
            yep im hearin ya
              baristas and roasters can only work with the raw product, which if just produced by standard numbers doesnt generate change and allow for improvement in techniques over time, same goes for producing shots, if we stick to the standard numbers we know, we are stuck within parameters that may not allow for certain roasts, ages, processing methods etc etc.
              not to say we shouldnt be aware of the numbers first, but innovation and improvement only comes from trying things outside our sphere of standards.
              as a couple of examples, a few years ago i was working with some of the current top baristas and we often noted that our prefences in terms of pullling a beverage would be outside of acceptable WBC standards in terms of time and volume, but our methods were governed by trial and error and taste.
              a well known WBC champ after being penalized for not dosing "correctly" in the first round finals questioned the judges reasoning, pointing out that the coffee he was making should be judged on TASTE, ultimately the judges who had judged 1s & 2s in the first round started appointing 4s and 5s to the same dosing procedure in the finals, he ultimately collected the prize but has gone on to question his previous techniques and now uses exactly the opposite style of dose, to good effect.
              how then do we call dose a standard without reference to the coffee and taste?
              should we apply a standard roasting curve to a high grown central, and fresh wet hulled sumatra and a full natural? or should we be aware of the numbers but not governed by the dogma of correctness, therefore allowing for something new and outside the curve..?
                as a couple of examples, a few years ago i was working with some of the current topbaristas and we often noted that our prefences in terms of pullling a beverage would be outside of acceptable WBC standards in terms of time and volume, but our methods were governed by trial and error and taste.
                a well known WBC champ after being penalized for not dosing "correctly" in the first round finals questioned the judges reasoning, pointing out that the coffee he was making should be judged on TASTE, ultimately the judges who had judged 1s & 2s in the first round started appointing4s and 5s to the same dosing procedure in the finals, he ultimately collected the prize but has gone on to question his previous techniques and now uses exactly the opposite style of dose, to good effect.
                great post......
                [smiley=tekst-toppie.gif]
                  Amen to that..... Zane.
                    Instead of "standard" how about you call it "safe starting point"?
                      Good points Zane
                      You remind me of a saying that opens up the way to innovation and new ways of doing things:
                      What if....... then perhaps!
                      A sort of Edward De Bono approach to lateral thinking :
                      Outside the square are endless possibilities.
                        thats why having known reference points works in our favour too..  safe starting ground
                        Rusty said: "whatever can be measured can be controlled" -err, if its been measured it is in the past.
                        thus what we have are a set of data points
                        we then make an assumption about a future event, a prediction, which is educated guess.= at best.
                        a set of data points, no matter what the resolution, is never the organic thing that is living coffee production, changing consumption patterns, and evolving plant.
                        if we served today the espresso we were happy with ten or fifteen years ago i think much of it would taste like swill (apart from tasting a little old ); will the coffee we make in ten or fifteen years from now make what were drinking today seem like swill? probably not (but possibly), certainly changes will come in perception and expectation.
                        thats what learning is all about.
                        the best coffees are often the most surprising, challenging to our idea of what is a great coffee, precisely because they come from outside our sphere of knowledge
