Hi everryone! Are there any uses for used coffee grounds? Ive noticed some Starbucks stores pack them into 2 kilo bags and whoever wants them can take them home. They say its good for garden plants. Are there any more uses for them?
used coffee grounds
Re: used coffee grounds
Someone needs to find a critter that will inject them with an excretion that turns them rock hard. We could all get rich building houses out of them then and make a killing in the real estate market!
Java "Yet another great idea" phileToys! I must have new toys!!!
Or you could turn them into car air freshener pucks. Stick a chain in them and hang two from the rear vision mirror fluffy dice style. That way other drivers will stay well clear because its obvious you will be on a caffeine high and unpredictable.
Maybe I could insert grounds in nappies to filter the stench, but I fear that there is nothing that strong in existence yet.
I cast many a thought in the direction of the army of worms in my compost bin.
It was bad enough when we fed them all the household refuse to convert to a compost the garden never sees because we dont have one (a garden, that is).
Now, they are a wriggling mass of mess high on stale caffeine.
I wonder whether they anticipate with greedy glee the next dose of Colombian Supremo...only to be disappointed when the mouldy pucks of Ethiopian Djima descends upon them.
Yes, I have guilty feelings about that.
I also ponder whether this drug of addiction is causing them headaches of migraine proportion.
Are they afflicted with lethargy, refusing to compost (the garbage, that is) until theyve munched through their morning fill of caffeinated spent pucks?
Its all food for thought which has opened up a can of worms with ethical implications.
Robusto
- 1 like
Good for a myriad of things. Garden wise they can be added directly to soil around plants for water holding properties or added to compost beds. I read somewhere alot will effect soil acidity but the value was a negligable increase, and not as the basis of the soil, just an additive.
I used two loads to fill some holes dug by the fearless guard dog.
Not so serious.
You could dry out the puks, crush and use as an abrasive in a sand blaster unit for metals that where too soft for regular blast abrasives.
Toss pucks instead of coins at two up gatherings tomorrow!! Now that Id lke to see.
Harden them and turn into key rings, earings, neck chains - coffee puck bling?
Roller blade wheel replacement?
How about replacement fillings for brake pads in cars. What a smell every time you hit the anchors!! ;D
Boris
- 1 like
found this .... http://frugalliving.about.com/od/uncommonuses/a/coffeegrounds_3.htm
Used coffee grounds as a beauty aid!
Coffee grounds go on the attack against cellulite, dead skin and gray hair, among other things. Brew a cup of coffee and after youre awake from it, use it for these personal beauty ideas.
1. Steep a cup or so in hot water, then use as a rinse to help cover gray.
2. Coffee grounds make a gentle exfoliating wash for your face. Wet your face and scrub with a tablespoonful of them.
3. Fill a muslin bag with used grounds and scrub yourself with it in the shower. Its a gentle exfoliator and deodorizer in one.
4. Rub warm, wet coffee grounds onto your skin and cover with plastic wrap for a few minutes before rinsing to fight cellulite.
5. A quarter cup of grounds mixed with an egg white makes a toning and firming facial. Massage it into your skin and allow it to dry, then rinse. If you have dry skin, follow with a moisturizer.
Or ... Crafting with Used Coffee Grounds : http://frugalliving.about.com/od/uncommonuses/a/coffeegrounds_4.htm
And in out next installment How to prepare coffee grounds as an anti-laxative :/
- 1 like
Originally posted by Dennis link=1145245907/0#9 date=1173925811hmmm, methinks Javaphile has me in his radarscope!
Java "Search engines are your friend." phileToys! I must have new toys!!!
Originally posted by Viviane link=1145245907/0#11 date=1173929456I just tip them onto my garden and wait for the next lot of rain to do its stuff.
Originally posted by Dennis link=1145245907/0#12 date=1173930536Originally posted by Viviane link=1145245907/0#11 date=1173929456I just tip them onto my garden and wait for the next lot of rain to do its stuff.
