Re: Post pull dribble
Just thought Id post a quick update in case someone else has the same issue.
Basically, after acquiring the non-pressurised basket and getting the grind right, the problem all but disappeared. Its a whole new coffee machine.
Thanks to everyone for the advice here and elsewhere in the forums... [smiley=thumbsup.gif]
Post pull dribble
After the steaming, its nice and dry. But just after the pull, it is usually pretty sloppy. It was the same for the Gaggia.Originally posted by 0B242D2F38072B242B2D2F272F243E4A0 link=1278619975/3#3 date=1278632882Is the puk sloppy or nice and dry at present..If dry and a slight shower screen imprint (SLIGHT), then just the machine and the way it releases pressure or has a little blow back from the steam side ?
Hard to say... Gut feel.. Under dosing... But the only way to prove it is to try and then make teh call.Originally posted by 73657A7865757E6264170 link=1278619975/2#2 date=1278632608Dosing levels... as in too much or too little?
Is the puk sloppy or nice and dry at present.. If dry and a slight shower screen imprint (SLIGHT), then just the machine and teh way it releases pressure or has a little blow back from teh steam side ?
Thanks AM...
Dosing levels... as in too much or too little?Originally posted by 052A23213609252A25232129212A30440 link=1278619975/1#1 date=1278628338YES... And as to how the system works and your dosing levels..
Ha! if youve tasted my coffee, it could be the best part :POriginally posted by 052A23213609252A25232129212A30440 link=1278619975/1#1 date=1278628338It could be the best part of the shot
But... my non-pressurised baskets and grinder are due any day now...
YES... And as to how the system works and your dosing levels..Originally posted by 76607F7D60707B6761120 link=1278619975/0#0 date=1278619975the consequence of owning low-end machines?
Originally posted by 76607F7D60707B6761120 link=1278619975/0#0 date=1278619975In regards to achieving the "best shot" possible, should the "dribble" be discarded or included?
I would not ...
But then your the only one that can decide if it makes the final result any better.. It could be the best part of the shot
But I doubt it.
Post pull dribble
This is probably a silly and pedantic question, but Im curious so Ill ask anyway. And sorry about the title... I tried to resist... :
Anyway, I currently own an EM5600, my previous machine was a Gaggia Carezza. On both machines, while steaming the milk (after pulling the shot), a "dribble" of coffee comes through the basket.
Is this normal-ish or simply the consequence of owning low-end machines?
thank you peoplesTags: None
