How humidity affects grind particle size
  • baristasoul
    Re: How humidity affects grind particle size
    Hi Sparow
    The grind size should go courser if humidity increases.
  • Sparrow
    started a topic How humidity affects grind particle size
    Hi all! I have an understanding that humidity affects grind particle size, but my question that I cant seem to find an answer for, is the following: when humidity increases, does the grind size as a rule need to be be made more coarse or fine? Or is there no rule and it could go either way?
    Thanks!!
