Grease
  • Grease
    My steam knob on my Giotto is squeaking. Is there a particular kind of grease I need to buy and any recommendations where I might get it?
    Thanks, in advance...
    Re: Grease
    bunnings or J-car = "inox "  food grade been posted a dozen times
      Re: Grease
      I use INOX MX6.
      http://www.dibartoli.com.au/product/Food_Grade_Machinery_Premium_Grease
      Food grade and doesnt melt.
      Some Repco stores also stock it.
        Re: Grease
        Depends on the actual location of the squeak - if the thread in the tap is exposed to the steam when the tap is open, use Inox. If its external to the tap (where the knob screws in/out on the body of the tap and pushes or pulls a plunger) or has a seal or O-ring between the shaft thread and the internals of the tap, use a copper anti-seize compound. The anti-seize keeps the threads lubed much longer than the Inox does, but isnt food-grade so has to be kept away from the steam passages in the tap.
