Hi all, I purchased some beans from a roastery and included some decaf for some visitors who dont like caffeine after a certain time of day..anyway I got it pre ground (have Lelit Combi) and it must be too coarse because it just pours out. Tried tamping quite hard which barely helped - is there anything I can do except bin it?
Decaf pre-ground issues
Re: Decaf pre-ground issues
If it has supposedly been ground for a pump driven espresso machine but turned out to be too coarse for that, then in theory it could be close to a stove top grind.
Try it and see, and adjust your technique to suit once youve run the first pot through.
Rgdz,
A.
Your going to find it virtually impossible to get good extraction using preground coffee in an espresso machine. The band for the right grind for espresso is very narrow and varies greatly between machines (and baristas), it will also need adjusting as the beans age. Denniss advice is good, a french press (or stovetop) will be much more forgiving.
Decaf is also notorious for its short shelf life, even as whole beans, so preground is probably best avoided. Why not buy beans and grind yourself, since your machine has a grinder?
Sorry but to keep any coffee beans or ground in the cupboard simply on the basis of or on the off chance that someone drops in and wants decaff, is to shoot yourself in the foot. This is because you would need to keep freshening up your supply of beans say for argument sake every two weeks, and chuck the old stuff whether it had been used or not otherwise it just wont make a palatable coffee the older it gets.
Unless you happen to have a reasonably constant turnover of decaff, if it is only going to be used sporadically and in small amounts it would be better to keep a jar of instant decaff in the cupboard for those that want it.
Rgdz,
A.
