I had a little shot glass size measuring glass with measurements in ounces and mililitres up to 30ml. Dropped it while cleaning and it broke. Anyone know where I can buy a replacement? Prefer to go to shops to buy rather than online.
Measuring Shot glasses
Re: Measuring Shot glasses
House, minimax, essential ingredient and other homeware stores sell them.
Price varies; from $18 for a 3 pack upto $12 per shot glass...
StAli and 1st Pour (Veneziano) have the bumper shot glass in stock, 30ml
For calibrating the pour, I like to use the coffeeparts 60ml one cos I can just use one shot glass - it is wide enough to catch the pour from both spouts.
http://coffeeparts.com.au/accessories/cups.html
After reading this post i decided to by the measurement cup from coffee parts so will be able to do some adjustments on the weekend. I often wonder how often i should calibrate my grind etc. but the difficult part in all of it is to get a suitable cup with a measure wide enough to take a double pour.
For $6.50 its not bad.
I am doing a barista course on Saturday morning so it will be interesting to see how the experts do it all.
Mal
Any ordininary household glass of suitable size will serve the purpose for calibating pours. (from liqueur glass upwards)
Then use a cough medicine measuring cap with graduations marked on the side to pour out 30 ml of water into the glass. Mark the level with a permanent marker, or stick on a thin strip of adhesive.
Do likewise at the 60 ml level.
I like the Pyrex ones from general trader, measurements up to 30ml/1oz and 60ml/2oz when filled to the rim.
Dimmeys has non measuring ones I think I paid $2 for 12 or something ridiculous like that, then just drew a line at 30ml with a permanent marker. Get the really thick ones that are round at the top and octagonal at the base, 30ml is about a cm from the top.
When using shot glasses and similar, do others find that they lose crema when pouring into the cup or glass to serve it in? Or is it my dodgy technique?
Also, when measuirng the 30mls, does the crema on top count or do you only measure from the black... ie. the crema sits above the line?
Originally posted by PiccoloLatte link=1199852082/0#10 date=1199930326When using shot glasses and similar, do others find that they lose crema when pouring into the cup or glass to serve it in? Or is it my dodgy technique?
To count crema or not to count, that is an age old question.
With a good machine, and a good technique and fresh beans, most of the initial volume in the cup during the pour tends to be crema. Obviously you dont count that. As the pour progresses, the bubbly crema dissipates. The coffee may also turn blond before the 60 mls is poured, so you dont want to keep extracting just to make up the nominal volume.
I aim for 60 mls plus or minus a few mls of settled crema.
