Re: Growing coffee
Probably roots, AM: wilting and brown spots. Sounds like it if your other plant is now recovering.
Fusarium wilt should show significant yellowing of the leaves before they start wilting. Nematodes often show up as significant stunting of the plant before you see symptoms such as wilting.
If you are over-watering and drainage is poor, the roots die off and the plant has no means of taking up water. Removing the fruit will help as its survival technique is to throw its reserves into reproducing itself when under duress.
Planting marigolds around the base might help deal with the nematodes if your garden has that problem but this is usually advised a few months before planting any susceptible species.
Try this site but you might want to consult a specialist.
