Coffee per Kg?
  • Coffee per Kg?
    For each 1Kg, how many standard cups of Latte - Cappuccino could you make?
    Roughly?
    Thanks.
    Re: Coffee per Kg?
    Figure 7g per shot. Roughly 10-15% ~100-150g wastage. Around 120-130 shots per kilo.
      Re: Coffee per Kg?
      I would say 100 cups of coffee including wastage of "working coffee". 7g is an ideal weight of coffee per single basket, but we all know were packing at least 16 to 20 grams per double basket. Depending on the age of the coffee I am using, I pack anywhere between 18 to 20 grams in a La Marzocco handle.
        Re: Coffee per Kg?
        I use a Synesso 20g basket all of the time, so even though I dont measure the amount per kilo it would equate to 50 shots, converted to standard shots probably around 130ish allowing for wastage etc.
          Re: Coffee per Kg?
          Commercial or domestic?
          Id be hard pushed getting more than 100 coffees from a kilo.
          Lots of places use double shots for take away cups so that comes into consideration.
          Staff coffees, grind adjustment (hopefully), the occasional redo.
          In a commercial setting Id be thinking more like 80 coffees per kilo, thats just me thinking out loud, not years of experience in a commercial setting. Wheres Chris ?
            Re: Coffee per Kg?
            Yeah, i should have specified in a Commercial setting.
            I just got thinking about how much turnover the "good" cafes pull in weekly, but i guess everyone has opinions on what is good.
            I was reading Campos go thru like 165Kg per week .... Wow!
              Re: Coffee per Kg?
              In thailand Framey 8-)- but correct you are- more like 80...
              I worry when people ask how many per kilo. It often implies that its all about the buck. For me, its usually a guarantee of bad coffee.
                Re: Coffee per Kg?
                80 coffees per kilo is about right allowing for wastage but the best way to find this out is to do it for yourself. Likewise if this question is in regard to operating a successful cafe - you need to know the answer to these sort of questions before you get started.
                  Re: Coffee per Kg?
                  Non-commercial:
                  I use an LM double basket, 20g IIRC last time I measured.
                  So that would be 50 doubles or about 100 singles.
                  I wouldnt put my wastage any higher than 10%.
                  That would mean about 90 singles/kg I think.
                    Re: Coffee per Kg?
                    165kg/week at Campos
                    Even at my more conservative 80 coffee/kg 165 x 80 = 13200 coffees a week
                    Campos (Sydney) are open 54 hours a week so, 13200 / 54 = 244 per hour on average.
                    Thats 4 coffees every minute of the day, all day, six days a week.
                    Campos do have an operation in Brisbane now, so maybe combined wet and dry coffee sales in both locations could add up to 165kg maybe...
                    Then there are wholesale accounts.
                      Re: Coffee per Kg?
                      There was a guy on another site who works at Melbourne Uni, he was sure he made 650 cups per day, using a 40 sec extraction.
                      The poor guy must have been a Blurrrrr!
                      Take sage advice from another CSer and try it yourself, see how many you get from a Kg.
                      Like Chris says, once the stats and stories flow its a bit hard to see the wood for the trees. If your looking from that angle your always going to get a different answer.
                        Re: Coffee per Kg?
                        Campos sink a lot of shots.
                          Re: Coffee per Kg?
                          Originally posted by 2muchcoffeeman link=1203826078/0#6 date=1203829548
                          ... I worry when people ask how many per kilo. It often implies that its all about the buck. For me, its usually a guarantee of bad coffee.
                          EXACTLY! Ta Chris
                          Any barista worth their salt will be wasting 200gms of that kg through the day altering the grind & tasting extractions, to ensure optimal shots for their customers.
