Coffee Styles - definitions or resources
  • Coffee Styles - definitions or resources
    Sorry to be such a noob but is there a thread on CS or an internet page that lists descriptions of all the coffee styles. Ive search both the CS and google and get lots of hits but nothing with what Im actually after. I mean, you cant make a coffee if you dont even know it exists ;D
    Until a visit to Coffeehorse place I only knew short/long black, Flat white, latte, cappacino and machiato. Now I can add ristretto to that list but Im sure there are many more and Id like to know
    Re: Coffee Styles - definitions or resources
    Im sure you can find lots of web sites with various definitions of different coffee styles. Some day you might even find some that agree. ;D
    A search here (remember to change the default search time from 1 week) will give you an idea of the debate on something as simple as a ristretto.
      Thanks Greg,
      I can add a few more styles to the list.
        Do you mean a "coffee menu" similar to this one:
        espresso menu
        Espresso / Short Black
        Serve in a 70-90 ml demitasse cup & saucer. Extract 25-30 ml of coffee in 25-30 seconds-traditionally served with a glass of water.
        Long black, Americano, or Caffe Lungo
        Fill a 170-220 ml cup 1/2 – 3/4 (90-150 ml) with hot water and top with a double espresso (50-60 ml) or doppio ristretto (30-40 ml) – served with a saucer, spoon and sugar.
        Flat White
        25-30 ml shot of espresso topped with freshly heated silky-smooth milk into a 170-220 ml cup leaving up to 5 mm of foam. Serve on a saucer with spoon and sugar.
          Whats the difference between a Flat White and a Latte foam quality? From the above description it sounds the same.
            The critical issue is all in the word "about". ;D
            There is a debate going on here about exactly that issue now. I expect it to be resolved in the next decade or so. :
              Originally posted by 2F2A37372F26312C362D272E222D430 link=1251777809/3#3 date=1251804603
              espresso menu
              Flat White
              Yes, this is exactly what I was looking for
                Id always pull the coffee onto the sugar to help the sugars completely dissolve.
                Places like Campos dont change the stretch of milk between a flat white & a latte, but just the coffee:milk ratio. Generally speaking, Latte = 10mm foam, Flat White = less, Capp = stiffer or more stretched milk.
                cocoa powder should be offered with a capp. in my opinion but not put on by default
                  Please tell me the difference between a flat white and a latte.
                  I have yet to have someone explain to me the difference between a latte and a flat white.
                  Knowing this is such a noob question, but Im even yet to do the free sunbeam course but have been asked the question myself, so wish to appear knowledgeable.
                  Thanks,
                  Peter
                    Re: Please tell me the difference between a flat white and a latte.
                    Hi Peter
                    Welcome to the land of snobbery. Youll get differing understandings of each drink. However, according to the highly regarded Barista Techniques by John Doyle, both of those drinks consist of an espresso topped with silky-smooth textured milk. The difference is in the depth of foam in the resulting drink: about 5mm for a flat white; about 10mm for a latte.
                    Luwaks
                      Thanks,
                      Peter
                      ^^^^^ Search button is your friend Peter http://coffeesnobs.com.au/YaBB.pl?num=1251777809
                      Hope that helps
                        Originally posted by 616D646467676E777176020 link=1251777809/9#9 date=1255229184
                        Hi Peter
                        Luwaks
                        Correct me if i am wrong, but a flat white is usually served in a broad cup whereas a latte is in a narrow glass. So the actual VOLUME of foam on top will be roughly equal.
                        Taking this further, can we then say that the volume of espresso, milk amd foam is identical for a flat white & latte, and only the presentation differs?
                          Get "them" to tell you what the difference is and then make it their way. ;D
