Originally posted by 0C0C0C460 link=1277698700/23#23 date=1277896722
I dose a little differently than you with the single. I dose tap and then rest the (heavy) tamper in the basket which settles the bottom of the puck, then dose, tap, "level" using dosing tools then firm tamp. This extra soft tamp at the start of the dosing routine helps produce an even puck which is necessary with the shape of the single basket.
Try that ristrom and see if that helps! Works for me
