Different pours from double and single spouts.
  • blend52
    Re: Different pours from double and single spouts.
    Originally posted by 64606A626B6C656568383A090 link=1341352269/0#0 date=1341352269
    single dose set to 15g basket same grind much faster extraction? still tastes fine but not ideal any ideas or suggestions?
    ..What is .."much faster extraction" ??
    Are we talking a 10sec pour ?.. or a 25 sec pour .? ( assuming your "Normal" is about 30 sec ?)
      If the taste is good, why worry ?
    Otherwise,  what would you normally do to adjust the extraction time on any basket ?..
    .... ..grind  adjustment !
  • David8
    Originally posted by 2F2B212920272E2E237371420 link=1341352269/0#0 date=1341352269
    Hi all slight issue I cant nut out,grinder kony electronic machine linea, baskets 22g vst and 15g vst.Grind set with 22g basket double spout pouring just how I want it,single dose set to 15g basket same grind much faster extraction? still tastes fine but not ideal any ideas or suggestions?
    This forum is full of comments about the differences between singles and doubles. Check put gregs post for one. http://coffeesnobs.com.au/YaBB.pl?num=1341197814/9#9. The big long one by Pullman Espresso towards the bottom. The baskets are constructed differently and have different quantities of grinds in them. So yes they behave differently. Suggestions? Updose the single, if possible. Preferably use a second grider for singles.
  • mickbella13
    started a topic Different pours from double and single spouts.
