The question of shot volumes
  • The question of shot volumes
    I'm confused a little by this. I know I should be guided by taste, but I'm curious how everyone else is having their coffee...
    Here's how I have mine. I make a cappuccino for my dad every morning and a piccolo for myself. I use a double basket and spout and pull a shot 18-19g of coffee shot, both spouts pouring into the one cup, cutting it off at the 22-23s mark before it turns blond at all (still brown). I do this for both drinks I prepare. I.e. pull 2X18g shots. No coffee is let to flow into the drip tray.
    My questions are... Is this a double ristretto? If I let the shot end in the usual 28-30s or when it blonds or longer??. Is that a double shot the should end up in 2 cups? But if I do that the resulting coffee and milk tastes too weak for me. I have seen another friend prepared a piccolo for me using the same BDB machine with letting the other spout drip into the tray and it was ok as a piccolo. Didn't ask if he used a triple shot basket or timed his shot.
    What do you guys do? What are your shot ratios for cappuccino and piccolo? I'm curious...
    =(( drinkable coffee down the drain?
    i do something very similar to you and find that really suits my palate. from the little knowledge i have, it does sound very much like a double ristretto to me but the timing is also influenced by your grind.... so i guess it isnt the most sensitive of measurements? what kind of volumes are you pouring? =) im doing 40mls on 16g of coffee from poured into one cup and filling it up with approx 60mls of milk when not having an espresso.
      That is pretty much what i have settled on for my taste when i fire up the machine.... usually 16 - 17g coffee aim for 40 - 45ml in around 28s.
      Any more than 60 - 80ml of milk for me and it gets a too milky and i loose the "coffee"
        The 18 gm of grinds, pulled for shorter volume or shorter time (big disagreements here) is a doppio ristretto.
        My doppio ristrettos go into a 90 ml cup that is topped up with steamed milk (when a milk drink is wanted). As Steve says, more milk and I lose the coffee.
          I think so...
          This is also my favourite way to make a latte
            Hmm... I just bought proper piccolo latte glasses (100ml) and Di Bella incasa cappuccino cups (can't afford the ACF ones). And because the volumes are a tad less than what we're used to. The drink tasted almost too empowering now! 40ml with 60ml of milk in a piccolo taste way stronger than what I get at my usual cafe. I'll experiment with 18g 60ml shots into 2 cups one cap and one piccolo tomorrow and see if that'll taste less empowering.
              That's basically what I do with my 90ml Province glasses, and the result tastes pretty good to me. Hard to get latte art in those little suckers though!
              I've a tenancy to stop my milk drink shots a little shorter & darker than I use for short or long black but that's just me.
                So which one do you do again? 18g into 40ml 2 spouts in one cup or 18g into 60ml making 2 cups?
                  One of the spouts from the double basket - couldn't tell you the weight as I dose by eye & it depends on the machine. Shot in each one ~25ml, depends a bit on the bean really. I sometimes cheat a bit and actually use the volumetric pour (which I program to 50ml), all personal pref when it comes to that.
                  Sometimes I do the whole double, still maybe 50ml, just for something different. And sometimes, actually fine up the grind a little for a tight ristretto pour of perhaps 45ml.
                  So many ways to get so many different flavours ...
                    That's it WA, you have nailed it!
                    It's all about personal experiences/preference in achieving a result that gives you that "ahhh... yes" feeling on the taste buds.
