Does 18g Basket mean you SHOULD be using 18g of beans?
  • thegoner
    These cost about $7 delivered. It takes 2xAA batteries.
  • okitoki
    Go to ebay and can fine small cheap ones.
  • renza
    what do you guys generally use to measure the weight? I have a set of digital scales, but its only accurate to 2g, so not all that useful. Cheap is good too
  • msydes
    just had a read -- glad to see it's normal!
    thanks, interesting thread.
    ~M
  • Steve82
    You might consider just reading this thread.
    http://coffeesnobs.com.au/brewing-eq...been-like.html
  • msydes
    started a topic Does 18g Basket mean you SHOULD be using 18g of beans?
    Title says it all really.
    I have a VST 18g (and love it), however I actually bothered weighing how much beans I was using per shot and it was closer to 20.5g. I just fill basket, lightly tap to settle grounds, flatten it off with my finger to all edges (not applying any down pressure, simply pushing the beans around), and tamp.
    I'm a fan of the 'if it ain't broke, don't fix it', and I have no problems with my shots, the pucks look just peachy, however technically, should I be adjusting my grind and using less beans per shot? If so.. huzzah, more coffee per kg!
    ~M
