Almost every time I make a second brew too soon after the first, it fails.
Hardware:
Wega Mininova Classic
Wega 5.8 grinder (same as Compak K3 Touch I think)
Bottomless portafilter basket, maybe a Synesso
I make the first brew, ~18g of coffee for ~18-25g of coffee depending on the grind and brew time.
If I wait for long enough, maybe 10 minutes, the second brew is fine. If I make a second one immediately after the first, it's as though I've ground much finer or tamped much harder or something's blocked. None of those are true. What I usually do is clean out the basket and put it back in place to stay warm then drink the first ristretto then straight onto grinding the second. All the variables are the same. The machine should be more than powerful enough to make a second cup and the pressure is straight back up there as soon as you shut the water off again.
The only thing I can think of is that the first grind goes into a dry basket and when I put a second grind in it's usually into a wet basket and maybe the first dry grinds hitting the wet basket block the filter holes? But I'm not sure because I think that if I wait the 10 minutes it's sometimes also still wet (maybe?, I can't say that for sure).
Any tips to eliminate this annoying trait? I failed twice this morning. First brew great, second brew about 5g of coffee from ~18g of grind after 30 seconds, third brew 18g of coffee from ~18g of grind after a minute and it sputters and drips and just doesn't come out.
I've had the machine for a year and it's always done this. If I have guests for coffee I can't do a run of them in a row and it's not really feasible to wait 10 minutes between brews.
Hardware:
( I'm really surprised you don't actually). Out of curiosity, you you clean the shower screen between shots?
) It reduces the amount left in there considerably and it only takes a little practice before I could stop the grind short, get the extra and still be at 15g - 16g in the basket.
