Help!!
  • mborzini
    Dad has done some reading has chosen some beans. Thanks!
    Is your dad doing the roasting too?
  • Barry O'Speedwagon
    What sort of nick is the grinder in? Is it the same grinder that you used to use, and is now getting a little tired?
  • mborzini
    I don't see what he's doing...I can't.
    Maybe our palates are different...he reckons he's not over-extracting.
    He would like to ask if there are other beans he could try where he wouldn't need sugar.
  • chokkidog
    Originally posted by mborzini View Post
    Hello,
    Before my accident I would;
    - roast my green beans in a bread-maker with a heat gun
    - make espresso with my Rancilio Rocky/PIDed Silvia
    I would make absolutely delicious shots using the beans from Yemen.
    I would never add sugar.
    Now, my Dad goes through this process but always complains that he must add sugar, even when he uses the beans from Yemen.
    He wants to ask if there are other beans he should try.
    Appreciate your help.
    You've come to the right place mb but some clarification would help.
    Your dad wants sugar.... let him have sugar!
    When you made it .....you didn't want sugar. No problem, your palates are different.
    Since your accident...... are you still drinking coffee? Are you able to roast and make it yourself?
    The way your post reads.... your Dad prefers sugar but you don't.
    Is there something missing here mb??
    Reading between the lines it sounds like your unfortunate accident is part of the dynamic but there seems to be some gaps in the info
    you have provided.
  • smokey
    Not enough information, can you please describe what your father is doing? Walk us through his process because he must be doing something different to ruin a Yemen espresso.
    If everything is exactly the same then I suspect that he is over extracting the shot and pouring the bitter ends into the cup rather than stopping when it blondes. Another could be he is not grinding fine enough...
    But lets get some more info and see what the more experienced members have to say.
  • mborzini
    started a topic Help!!
    Help!!
    Hello,
