Hello all, hope I am posting this in the right section.
I am in the process of building a coffee van, my coffee machine is a 2 group Faema E98. I'm looking at 12v water pumps to pump from the water storage tank to the water filter and coffee machine. I am getting a bit confused between pressure and flow. One of the pumps I am looking at is 3.5 litres per minute flow rate and the other is 12.5, but both are 35psi pressure. The 3.5 one has a 10mm pipe inlet and outlet while the 12.5 one has 20mm pipes. The 10mm pipe just looks very small to be feeding the coffee machine.
Does anyone have any experience on what flowrate or water pressure I should be going for?
Thanks in advance
Thanks in advance
