Hi guys,
I know that there have been several threads close to this topic, especially on other forums, but I am after some Aus specific advice.
I have a ECM Technika Profi plumbed in with a Brita C150 PLV (350kpa) filter.
350kpa is around 50psi. From what I have seen, I should be lowering this further to around 40psi.
Just wondering what pressure most of you plumbed in people are running and what are you reducing it with?
The only regulator I can find seems to be one from the US.
Currently my machine ides at this line pressure which means when the pump is on it is pushing up to 11bar or so.
Before I go and adjust the pump pressure, I just wanted some advice on line pressure and I'll work the rest out from there.
Also, would you recommend a portafilter guage or can I trust the internal pump guage?
Thanks for the help.
My Christmas project "Bar Upgrade" is almost done...
