Hi All,
I am currently running an inline cation resin filter (for the coffee machine) and a twin system filter set to filter the water which is all delivered at low pressure through the second standard filtered water tap next to the regular kitchen mixer. The twin system is those large canister style that are a bit of a pain to replace (but not too bad at once a year).
We are about to embark on a new extension which will include a new kitchen. As its time to replace my current filters I thought it would be a good time to investigate updating for the new kitchen layout. As part of getting a more contemporary kitchen I was hoping to be able to find a system where I could deliver the filtered (and softened) water necessary for the coffee machine through a standard kitchen mixer to avoid having to clutter the bench with the second filtered water tap. The standard mixer tap I will be getting is the Caroma Liano (WELS 4 star rated, 7.5L/min).
I contacted the supplier of my existing filters (a highly recommended supplier through the CoffeeSnobs forums) and they have put forward two recommendations for "high flow" options, being:
1. Everpure 2CB-GW Filter
2. 3M HF15-MS
Digging a little deeper I am concerned that either of these two options would work effectively with a standard kitchen mixer. Based on the specs on one site I have found the Everpure has a Maximum Flow of 1.9 Lpm and the 3M flow rate = 3.8 Litre per minute. Given the Caroma Liano standard sink mixer is rated at 7.5L/min, I am concerned that these two recommendations would be too restrictive in terms of flow and would just be a trickle out of the mixer which would limit its use as the standard kitchen tap.
If this is true there are a few other options that have higher flow rates:
Everpure 4CB5-S Flow = 6.3 lpm
Everpure 4FC-S Flow = 9.5 lpm
I understand that the Brita C150 is a popular solution, but this would require the second tap which is what I am trying to avoid.
Before I jump into replacing the system I thought I would ask if anybody else has done something similar and can offer recommendations. I understand that having the filter running through the standard mixer would shorten the life of the filters but I would be happy to replace them more regularly if I can get away with not needing the second filter tap.
Hopefully my requirements and concerns are clear. Any comments would be appreciated.
Michael
2. 3M HF15-MS
Michael
