For durability I would recommend a plunger made from glass and metal rather then plastic. After that, I don't think it matters as the quality of the coffee will be the most important factor in your coffee enjoyment.
The Kmart ones do the job well, I use one often for pseudo cupping roasts, much simpler than Aeropress.
Its more about the roast / grinder / brewing technique.
After you buy one read this - http://www.jimseven.com/2010/11/04/c...-french-press/
Bit late now but I detest the plungers with the rotating plastic at the top with the filter. I think they are supposed to be for filtering out tea leaves if you use it for tea. Also the Ikea says it can be disassembled for cleaning.
Of course the Kmart one will come assembled already - you will have to assemble the Ikea one your self :-)
The Kmart one that is full plastic can be microwaved. Not sure it your supposed to. Have a similar plunger I use for milk frothing with aeropress/moka pot.
Yes, if for nothing else you can always use the plunger for frothing milk. I forgot about that.
I've got an IKEA one, and it works fine, but I use it for tea only. For $10 I think you can pick anyone of them and you won't notice any difference. It might have been a joke, but I think the IKEA one comes assembled too
