So I have a 2 group Boema that I'm building onto a small cart for events and am using a small Flojet diaphragm pump for supplying water pressure.
This works well for filling the boiler but whenever I try to make coffee, the resulting pressure behind the coffee puck is enough to make the Flojet think there is no flow of water so it cuts off. After a second or so when the inboard rotary pump is unable to sustain the shot and drops a bit in applied pressure, the Flojet kicks back in briefly, upping the pressure and switching back off. The rotary pump drops off, Flojet kicks back in and etc. etc. until the shot is done.
This doesn't appear to affect the appearance of the shot and it tastes fine but it's definitely not right.
Is this just a matter of using a different Flojet which has an adjustable pressure switch or perhaps using an accumulator tank to smooth the pump delivery? The accumulator is about $50 which is much less than a new pump.
It could possibly be the Boema at fault too as they use their own sort of PLV on the rotary pump inlet. I may call Boema and ask them about its exact workings which could provide some hints.
