Water filter supplier recommendation please!!!
  • MrJack
    Perhaps I should have said "almost" everything organic.
    Most of the time, additional treatment stages are actually upstream of the RO membrane - to protect it, and prevent scaling and fouling.
    There are various industrial membrane treatment "technologies" (nano, ultra etc.). However, the pores in RO membranes are small enough to reject just about anything (including viruses); significantly smaller than any microbe. Defects and leaks aside (which will affect any system).
    That said, it's true that if pathogen removal is a key design concern, you would usually specify more than one method of treatment.
    P.s. Did you write the Wikipedia page, or just read it?
  • Javaphile
    Originally posted by MrJack View Post
    If you're seriously worried, reverse osmosis will remove all organic materials.
    Not necessarily. Not all reverse osmosis systems/membranes are created equal. Membrane pore sizes can vary from 0.1 to 5,000 nm (4×10−9 to 2×10−4 in). Many, most per some sources, do not in fact remove all organic materials. It is for this reason that places such as Europe do not allow the use solely of an RO membrane for the production of bottled natural mineral water. In practice, a fraction of living bacteria can and does pass through reverse osmosis membranes through minor imperfections. This is why many reverse osmosis systems include additional water treatment stages that use ultraviolet light or ozone to prevent microbiological contamination.
    Java "Isn't science fun!" phile
  • MrJack
    To be fair, perhaps its the questions?
    It is not possible to say "how much" cysts it removes, without knowing what is in your water.
    A filter will remove particles down to a certain size (usually measure in microns - i.e. micrometres).
    According to "the internet" cysts can be anywhere from 1 micron to 20 micron. So, a filter which removes 99.9% of particles larger than 5 micron, will pass the smallest cysts. But if your water only has cysts greater than 10 micron, it will remove 99.9% of them.
    That's assuming it has any cysts in it at all...
    Originally posted by MrFreddofrog View Post
    Yeah, when I asked how one sales rep much cysts it removes they couldn't answer
    The correct answer was to tell you that he started counting but ran out of microscope time...
    Mrjack I'm in Perth. I actually think my water is fine but who knows.
    Yeah- WA is where espresso machines go to die and FWIW, Perth water in most applications means RO.
    Coffee filters and dual filters? They couldn't answer because it's not the way that coffee filters are designed. They're single filters. If you wanted to add a specialist additional filter- go for it, but that may be a job for two different manufacturers/suppliers specialising in different applications.
    Why are they replaced on a time rather than litre basis in most cases? Cut one in half after 12 months of home use or at the end of cafe life which will probably be litres rather than time and you will have your answer.
    Best bet is to have your water tested so you know what you have and then take things from there. Rather than grilling people who need to be generalist on hundreds or thousands of products, you might go to the manufacturer websites and do some research yourself.
    I feel sorry for the salespeople as your account sounds like they have now experienced a full in the glare of the spotlight grilling.
  • MrFreddofrog
    Yeah, when I asked how one sales rep much cysts it removes they couldn't answer but side stepped to talk about microns. So I asked them to explain their micron rating but they couldn't explain that either. At this point my confidence in the company evaporated and I went elsewhere.
    Mrjack I'm in Perth. I actually think my water is fine but who knows. It just annoys me all these filter companies with exceedingly few exceptions lack knowledgable staff who can substantiate their product claims.
  • MrJack
    The problem doesn't stop at retail. Often the sales engineers from the manufacturers don't really understand their products beyond the technical specs.
    What water are you filtering?
  • sprezzatura
    I had a water filtration expert tell me he uses 1 micron for cysts. I recommend testing your water (TDS and TH) and then calling WFS in Melbourne if you haven't had any luck with CS sponsors. I have been dealing with them when I have a bad water/expensive machine install. There are plenty of other options out there but the BWT filters and digi-counters are good gear.
  • sprezzatura
    Some of the filters that are rated high litres have a by-pass valve. If the by-pass valve doesn't by-pass water its rating dramatically drops (e.g., 36,000 to 9,500)
  • MrFreddofrog
    Thanks Dave, already spoken to them.
  • DaveD
    Hey ff,
    I'm not sure if you have spoken to them, but I thought Bombora Coffee and Water supplies were the goto people for filtration. Check out their website and give them a call if you haven't already.
    Cheers, Dave
  • MrFreddofrog
    Oh guess what, I just spoke to another "reputable" supplier. Their sales rep said they couldn't help me because they didn't sell twin cartridges but only singles. Argghhh.
    Edit: They just called me back for the 2nd time. The first time was to tell me their technician confirmed they can't help me. Now they have left a message saying they definitely can help me. I'm going to call them back as I'm now dying to know what they could possibly say. Stay tuned.
  • MrFreddofrog
    started a topic Water filter supplier recommendation please!!!
    Hi all
    This is sooooo frustrating. There are hundred of filters out their so I followed CS recommendations and spoke to two filter supplier CS sponsors. The most common one everyone recommends and another one that isn't really pushed on CS as a filter supplier but at least they still sell filters. Both left me very under-whelmed.
    While both were very friendly (full points there), neither were particularly knowledgeable. One could not answer very basic questions about verifying their product claims, eg how much cysts it actually removes and the other could not explain why their filter rated at 38,000L (most are 3,000L) still needs to be changed every 6 months, (like what's the point of buying a 38,000L filter then?). Both wanted me to speak to their product managers because they are only sales reps who don't know any more about the product than what is written on the side of the packet or their website (so much for product training..... grrrrr) . Obviously the product managers were not available.
    Does any one know of a water filter supplier who has sales staff who really knows their products?
    Argh!!!!!!
    ff
