G'day.
Keen to to understand something....
i understand and the idea that you get roughly twice the volume from a double basket in around the same amount of time. So broadly speaking, 30mls in 30 secs for a single, 60 ml a in 30 seconds for a double.
My question is, does the time change as grams increase.
by way of comparison
i just found I'm putting 18grs into a single basket, and have the grind calibrated to give me a 30 pour.
Should I be grinding coarser and trying to extract more volume from the relatively high dosage? Or maybe dosing less and grinding finer. Seems like a lot of coffee for 30mls.
if I switch to a double basket, not sure how many grams that takes but it's more, I'm getting the 60mls in 30 seconds from the same grind setting
is it the shape of the single basket restricting the flow so my higher dose feels ok with a 30 sec pour?
cheers
cheers
