Bean vs grinder vs machine vs method when producing crema
  • Bean vs grinder vs machine vs method when producing crema
    Hey snobs, had a small query for the masses. I have a nice little Ponte Vecchio export lever machine, breville grinder and fresh roasted beans from my local guy. I have been fiddling with the grind and methodology (preinfusion, amount of pulls etc) and can get a constant crema of around 3-4mm, which comes with a good drinkable shot. My question is prior to buying the lever I watched every YouTube clip I could to see people getting inch think crema, which made me wonder if it was due to my entry level grinder...
    So how do folks get such a large crema?
    Oh I shouldsay I drink milk coffees and this is purely out of curiosity
    Hi there
    are you using a naked portafilter? What about the folks in the video?
    That's an easy way to get a large amount of crema initially, but it will probably settle to the same amount you're getting.
    And are they using an Export as well? The spring in the Export will not be as strong as others (about 6 bar), and if you're watching vibe or rotary pumped machines they generate more pressure (about 9 bar on properly set up machine)
    A better grinder will always help to make a better coffee, but I suspect the difference here is whether or not the portafilter is naked.
    Also depending on how fresh your beans are, they will tend to make less crema as they go stale.
    Sniff
      Thicker crema doesn't necessarily equate to better espresso. 3-4mm sounds pretty good to me, and as Sniff says you might be comparing apples with oranges.
        Yeah same machine, just don't know about grinder and the beans they are using. My beans are around a week or two since ground so I would say they are relatively fresh.
        Like I said, more curiosity than anything else. Current it is a tasty drop and the crema doesn't disappear, which Im stoked with, its just when somebody produces an inch, I just went hmmmmmm
          A week or two since ground? Or do you mean a week or two since roasted? A week or two since roasted is very much the sweet spot for most beans, but if you're not grinding for each use then that will be a problem. I try to have the smallest amount of time between grinding and using the coffee - around 20 to 30secs usually. Most people say ground coffee is ok to use for 20min or so, but not much longer than that.
            I think we've just discovered your problem. I'm amazed you're getting any crema at all and that the pour is even drinkable!
            Java "Grind immediately before brewing!" phile
            Toys! I must have new toys!!!
              Yeah sorry, thinking one thing typing another......
              1-2 weeks since Roasted.....not ground. I grind when I need a coffee
                In that case I'd say your probably doing as well as your equipment allows. A better grinder would help, but as long as you are happy with the taste of your results then I wouldn't worry.
                  Yeah regretted getting the grinder, should have shelled out more,. The machine is great so can't fault it
                    Take a photo of your shot if you're worried about it. And if it tastes great then don't try and compare it to a YouTube extraction which could be different variables to what you're doing.
                    A pretty crema can still taste gross
                      Another way those people in video land might be getting thick crema is blending in robusta beans. Many companies do it including local roasters I personally know, just to improve the crema.
                      Maybe get someone else you trust to brew up the beans you're using and see how they go.
                        cheers guys, the most pressing issue i have at the moment is getting silky milk and not the thicker crema my wife is a barista and keeps telling me i need to go back to the drawing board and have another go at it. Tastes great but looks average
                          I wonder how you are getting on with your silky milk.
                          It makes all the difference to a good Flat white/latte.
                          Just get the cutting paper technique right and you will be laughing.
                          And never buy another cup at a cafe because yours are just the way you like them.
                          Rbn
                            Can someone explain the "cutting paper" technique ? I usually have the tip of the steam wand in middle of the jug ,just below the surface for about half the time then put it deeper for the rest of time till it's 65c . Reasonable texture , but room for improvement .
                              I think that's just a saying. As it refers to the chhh chhh noise at the start when stretching the milk
