Power rating
  • Power rating
    Hi again
    Just a quick question with regards to how much power my coffee machine draws.
    There's a label that says max 4850w so I would guess that's the pull while heating?
    Another just says 4500w, would that be at normal operating temp?
    I'm in the market for an inverter generator to power my rancilio and just want to be sure of things before I do
    Thanks in advance
    G'day mate....
    The 4500W most likely refers to the rating of the Heating Elements in the Boiler and the 4850W refers to to when the Boiler is heating and the Pump Motor (and any other small loads) is running.
    With regard to sizing the Inverter for this, are you going to be supplying any other loads such as a Frig, Pressurising Feed Pump, etc etc? These will have to be accounted for in the final decision. At the very least, I would suggest that you size the Inverter/Generator to the total of the major loads, then add another 50%....
    For example, If the total of major loads comes to 5000W, then the Inverter/Generator size recommendation would be 7500W...
    P.S.
    Who will be completing the work for you, wiring, distribution board (if needed), etc?
      20 amps or so. Watts = Volts X Current
      Most house circuits are 10 amp.
        Say what...
          No fridge at this stage I should be able to pass health regs with a good quality cool box with a few bags of ice.
          So I have the grinder, 150w and the pressure pump to give mains pressure is 60w. Generator I'm looking at will be a consistent 7.8kva which is 5500w but can go to 8.6kva
          Generator has rcd built in and I'm looking at a 15amp distribution block from a seller (can't mention names unless forum sponsors right?) which also has rcd built in
          So it's literally just plug and brew
            Sounds good to me mate...
              At full draw your Rancilio is going to hit 20+amps ... so choose your power delivery from the generator outlet carefully; there's many a slagged 15amp plug out there. I suggest a heavy-duty, caravan-style lead and a 20amp plug (4.16 amps appx. per kW). Your machine supplier can reduce amp draw by dropping an element if necessary.
                Segregating the heating element?
                Hello Everyone,
                I was just hoping that someone might be able to help me with an issue involving power for coffee machines.
                We have a 3 group SanRemo Venezia that we use as a mobile coffee cart for events. We have an isolation switch that cuts the power demand of the element that allows us to run our machine on a 15amp plug (as opposed to the original 20amp plug). This is great, however we are sometimes up against the wall if we arrive at an event and it only have access to 10amp sockets.
                Does anyone know if it is possible to segregate part of the element to potentially power it off its own socket. I am hoping that I can wire one part of the element it to its own circuit that would have direct access to a 10amp plug (no association with the rest of the coffee machine at all, I would try to make it run off the active switch for the coffee machine to make sure that it doesn't stay on when the machine is off. The remaining element can then remain on the original circuit that is part of the coffee machine. The idea being that when we come to a place with only 10amp sockets, we would like to be able to power up the machine (which will now only have 1/3 of the element active on a 10 amp plug), power up the 2nd element that is now running off its own power cord to a 10amp socket, and the third element will be isolated and not turned on.
                When we rock up and there is 15amp outlets, we will just plug both the 10amp plugs assocaited with the machine into a 15amp power board and away we go.
                This seems quite doable in my head, but I have never pulled the machine apart to see whats hanging off the end of the heating element.
                Thanks for your help.
                  Theoretically this will work. The element for this machine will have six poles. The big elements are six pole so three-phase power can be applied to them. In order to 20amp single phase 240V the poles are jumped (active and common respectively). Your isolation device drops two joined poles so the 5.4kW element is now, say, 3.3kW so a 15amp plug may be used.
                  The dangerous part is running a separate active 240V line which needs to be switched, isolated connected to the p/stat, and ... yikes! How about talking to a master electrician?
                    Agree...
                    Significant safety considerations involved here and a qualified, licensed person should be retained to legally make what ever modifications are necessary to achieve the outcomes you require...
                      Hi Guys,
                      Thanks for the feedback. Much appreciated. It made sense in my head, but I don't like playing with electricity, so I will definitely leave it to an expert. I was just trying to work out if it was potentially an option before engaging a professional. It sounds feasible though, so I thank you for your input.
                      Porter111
                        Originally posted by porter111 View Post
                        Hi Guys,
                        Porter111
                        If you go down this track the best bet would be for the electrician to put an interlocking relay on the power to the machine ( fitted internally) ; in other words BOTH power circuits need to be active before anything can turn on.
                          Or, a form of Priority Control to match operating circumstances.
                          Can be accommodated quite simply...
                            Hi Everyone,
                            Thanks for your responses. I just wanted to give feedback for those who would be thinking about going down this path.
                            I had the electrician come out and check it out. He was able to quite easily isolate one of the elements onto its own power lead still utilising the coffee machines rotary switch. We also have the ability to switch off one of the two remaining elements.
                            After completing the work, we were able to plug the whole coffee machine into 2 x 10amp plugs in my house and run the full coffee machine. He tested the ohms and found that if we run the two elements on the one lead, we just hit over 2400watts, but with one element isolated, its all good to go.
                            Have had two test runs now for events and the thing runs like a dream able to cope with two baristas running it flat out.
                            Next step is to install a couple an LED on the new 10amp line to indicate when it is receiving power, just in case is trips and you have no way of being aware that it has.
                            Thanks for your help and input.
                              Where are you located? This sounds like something I would want to do.
