Hi Guys
I thought I would post my success on how to brew espresso at home.
I have spent the last year and a half trying to find the best way to make coffee at home.
I read a few common myths and talked to many industry professionals.
The most common way I tried to make an espresso was identify what size basket you have. Say a 18 gram basket. Then you put that through your machine untill your grind is fine or course enough to produce 30 ml of espresso in 30 secs.
This is wrong.
Then industry professionals told me I need to brew according to ratios.
So say you put 18 grams of coffee through your machine then you need to brew in a 1.1 -2.5 ratio weight out.
So lets say I choose a 2:1 ratio. For my machine I would weigh 18 grams of coffee and attempt to get 36 grams of coffee out in grams not mills. I found that to do this it can take half to a kg of coffee before you can work this ratio out.
The simplest method ive found is. Weigh your coffee grounds at your basket size so for me 18 grams coffee for a 18 gram basket.
Leave your grind setting alone on your grinder for now. Purge your machine through your portafilter for about 10 secs. Then dry the basket really well.
Dose your 18 grams of coffee into your basket and run it through your machine.
Don't weigh or measure your shot simply time it to see its not going under 20secs and not over 35 secs.
Pay close attention as the shot pours out. You should see a very dark black shot come out, going to a ritch dark brown. The spout streams should look quite thin not to thick. As soon as you see the shot go to a yellow color stop the shot.
Have a look at your shot. If the shot is a golden yellow color it has not been extracted quite long enough. If it has dark blackish lines through it or mottling it has been over extracted. If it is a dark redish or caramel color with flecks of coffee in it that means you have the perfect grind setting for your machine.
For this method to correct an under extraction. Make your grind setting finer by 1 grind adjustment and repeat untill at the desired taste.
To correct over extraction make your grind setting courser by 1 setting and repeat till the desired taste is achieved.
This is nothing new that other people haven't done before but this is the most reliable method I have found and doesnt involve wasting lots of coffee.
Any comments appreciated.
This is wrong.
