Prisma Cold Brew Coffee
  • Prisma Cold Brew Coffee
    Another one for a gadget collector?
    Cold brew in 10 minutes! https://www.indiegogo.com/projects/p...ee-technology/
    How do they get the extraction in a fraction of the time? I wouldn't have thought you could bend the rules of physics and chemistry to this extent.
    Interesting if it provided the same result in that sort of the time.
      They did mention vacuum in the vid. But the time change is huge, it like 50 times or so faster.
        Just realised it only works on 120V.. what a bummer
          The have been contacted (not by us) to express interest in import of a 220-240V version...
            I guess that naturally leads to the question – what if you turned on your E61, and poured a shot before it had a chance to warm up, using pump pressure only through your espresso ground coffee? Same basic principle I guess…
            I feel an experiment coming on
              Might I suggest you put the portafilter (with the basket) in the freezer prior to your experiment
                You could disconnect the heating element. And grind fine enough for a 10 minute extraction!
                  And ice blocks in the tank
                    I realise that this was a joke, but Seattle Coffee Gear just did a video on this... results weren't good, apparently
                      Googled it …
                      https://www.youtube.com/watch?v=Nngt5xbEVpc
                      Might be worth a try anyway - just out of interest!
