Hi Guys,
I'm becoming a little confused over how to balance grind size and portafilter dosing. I have a Pesado 20 gm (I think) basket.
Essentially you want the basket about 4/5 filled so that the bottom of the showerscreen just touches the top of the tamped coffee, correct? Overfilled - not good, underfilled - not good.
But you're also grinding to a weight - say 18-20 grams. Won't the particle size of the grind (to a fixed weight) affect the volume of the basket filled (or am I missing some basic physical principles of matter)? If that's the case - how do you balance between weight and volume? Or does one really just grind to weight, while optimising the grind size, but not worrying about the resultant level in the portafilter?
Hope not a dumb question.
Thanks,
Paul
Thanks,
Paul
