Hey folks,
Ben here, the (relatively new) store supervisor of Di Bartoli Home Barista Centre in Sydney. How is everyone?
I'm enquring about cold drip coffee and the method behind making a perfect batch of it. We have a Tiamo cold dripper which, while lacking a lot of bells and whistles, does the basic job of slowly dripping cold water over coffee grounds just fine. I can run a batch of it, however I nearly always end up with the water channelling through sooner or later, leaving quite a few coffee grounds in the final batch and a compromised taste.
My ratio is 60g of light-roasted, coarse-ground coffee (finer than a plunger but coarser than filter) to 600ml of cold, icy filtered water.
I put everything together, pop a filter on top of the grinds, presoak the grinds, then slow the drip down to about 1 drip every 1.5 seconds. The first coffee drip is usually about 30 minutes after slowly the drip down.
Now here is where I run into problems. The water tends to back up over time, to the point where I have at least a few CM of water sitting over the grinds and the filter sitting on top.
I've read many methods and looked at many tutorials on YouTube. I'm wondering where it is that I am going wrong.
Thanks and regards
Thanks and regards
