After some advice regarding a coffee I recently had in the grinder. It was a light roasted specialty kenyan which was roasted for espresso, but was definately on the lighter side of roasts.
I run a Linea Mini and compak E5OD grinder, weigh in my shots and distribute via OCD. Brew temp around that 94 - 95c mark as it was a lighter roast. I run VST baskets and precision tamp, I almost never have any sprays or chanelling on the bottomless portafilter, but I was struggling severely with this one. I would get an OK extraction for maybe 7-8 seconds, then a very light watery style crema with pinholes starting to spray. I played with the grind and went finer, It helped a little, but still started to squirt after the initial saturation came through. I must have pulled 7-8 shots, all much the same. Taste in the cup was ok, naturally a little under extracted.
Any ideas on what this could have been? Is it more likely a coffee that was too light for a sufficient espresso extraction?
Since I have went back to some of my roasted coffee and some others and almost perfect extractions!
interested to hear peoples thoughts.
