Channelling around edges?
  • Channelling around edges?
    I'm trying to see if I can improve my pour and I think I'm getting some channelling around the edges - getting a naked PF to help see things better, plus to have the ability to use deeper baskets etc.
    Pours start out nice and slow but always seems to run faster sooner than I would like and I think blondes too early. Grinding finer just results in choking the machine, so I think the issue isn't grind size, but more to do with distribution or tamping.
    Around the edges always seems to be some pin-holes and/or large divets.
    I'm using a Jetblack PreciseFit Tamper which fits relatively well, but there is still some play - going to measure with calipers once I get some batteries. Basket is a La Marzocco I believe, but there are no markings to confirm (machine bought second hand). Definitely not the standard Rancilio basket though.
    Currently I'm tapping the side of the portafilter with my palm to distribute and then tapping down on the bench twice to settle before tamping. I'm going to try dosing into a small cup first to try and break up clumps before tipping into the PF.
    Any tips/suggestions will be appreciated!
    https://photos.app.goo.gl/lj2w2k9e3BRNpoZo2
    Certainly looks like it from the photo.
    But if I may, what is the divot in the middle and the faint ring where it looks like it was depressed on the outside?
    Could it be that the coffee is up against the screen and then the puck swells causing pressure on the middle (the divot) and the ring on the edge where the shower presses against it? That could in turn lead to an uneven extraction and channeling around the edges?
      That centre divot looks like the hex head of the shower screen screw. I'd be interested to know if that divot appears before pulling a shot, i.e. dose and tank, insert the portafilter but pull it out again before running the shot. If that divot still appears I'd suggest lowering the dose until it doesn't and fining up the grind to compensate. Your description of slow at first and then too fast too quickly sounds like overdosing and undergrinding. What is the weight of the beans you are dosing?
        I think the divot is the impression of the screw/cap screw holding the screen in place, the flattened area around the edge looks like the impression of the rim of the shower screen.
        Also looks to me like over dosing, makes a big mess and you will finish up with this.
        How old are the beans your using (when were they roasted) who roasted them, what type of grinder.
        Everything you say indicates stale beans too me.
        Suggest buying some freshly roasted beans and try again.
          The divot in the middle is the hex head from the Rancilio Silvia shower screen. I've seen the info on changing this out for a button head, but also seen lots of reports that it isn't as big a deal as made out to be.
          The faint ring around the outside is the shower screen edge.
          I'm dosing 20g in the basket, but I will check to see if there is an impression prior to pulling the shot. I used to fill the basket to a mound, distribute and then level off before tamping which resulted in a 22g dose (only discovered once getting some scales to actually weigh my dose!) and that certainly left a divot prior to extracting - for some reason I haven't checked since lowering the dose to 20g.
          Possibly I should be aiming for 18g in the basket with a tighter grind as suggested, so I will try that next.
          Thanks!
            I buy beans from the local cafe - they use Axil beans.
            Beans are delivered weekly to the cafe and they then bag them for individual sale.
            Batch I've got at the moment was roasted on 1st Nov, but possibly my storage methods aren't the greatest. The bags the cafe use are Axil 250g bags with a snap-lock top, but they don't heat-seal the top, so possibly air is deteriorating them faster.
            I'll buy a fresh batch and also try dosing less.
              Yep, the screw impression is no big deal.
              20 grams sounds well over dosed to me.
              Aaaaaand! the most important questions once again, how old are the beans and who roasted them, what are you grinding with.
                Still reckon it's stale beans, do you have a specialty roaster close by you can buy from?
                  Roasted on 1 Nov even with a little air ingress they are still probably okay - maybe not the best. However Yelta has a point with the grinder, can you get fine enough to pour a 30ml shot in 30 seconds?
                    Grinder is a Macap M2M
                    I can certainly grind fine enough to get 30ml in 30seconds, or even longer if I go too far - a click or two further will choke the machine.
                    I'll have to look to see if there are any speciality roasters nearby, but I often will get beans bagged the day they come into the cafe (which is within days of their roast date) and they get beautifully rich pours in comparison to mine - of course a Rancilio Silvia vs a La Marzocco Linea isn't a fair comparison , but I've seen some nice pours online!
                    There is another cafe in the area that carries Five Senses coffee, so I might pop in there and see if they sell beans and what roast dates they have.
                    I'll start with dosing less and grinding finer as the general consensus seems to be that 20g is overdosed, so that's my first mistake to rectify.
                    Thanks a lot to everyone for the help
                      Not to disagree with the wealth of knowledge Yelta has, but your beans seem (on paper at least) like they should be fine and two weeks since roast is acceptable.
                      See if you can dose maybe 16-18g in the same basket and grind finer to get a 30ml shot in 30 sec with the lower dose. I think the heart of the problem lies with the swelling of the puck and the pressure you get against your shower screen.
                        +1 to this and others thoughts on it
                        Yeah that looks like far too deep a hole to be left in the spent puck.. And yeah amount of coffee in the basket is definitely basket dependent. It's not that 20g of coffee is considered overdosing, but 20g for YOUR basket is overdosing.
                        Thanks!
                        Yeah I reckon that'll help a lot lowering the dose and finer grind. And also just to check when locking in the portafilter properly then removing straight away, if the puck is disturbed in any way it's too high a dose. Keen to see how ya go
                          I have been struggling with channeling for years and never managed to eliminate it on my Diadema Perfetta.
                          Usually one or two round the edge of the basket.
                          I have tried just about everything mentioned above but the channels persist.
                          I wonder if it is caused by excess pressure at the shower screen that is trying to push the water through the puck more quickly than is possible.
                          The coffee is still good and occasionally great but it annoys me that it happens.
                            G'day Rocky...
                            When was the last time you had the machine in for service and requested a "Scace" test and adjustment?
                            If everything regarding your grind, dose, distribution and tamp is Ok then it could be down to a machine adjustment.
                              Thanks again to everyone for their help!
                              Tried an 18g dose this morning - locked the PF in and removed it to inspect before pulling the shot. There was the ever so slight hint that the puck had touched the hex head bolt. No indent, but just a small section where you could see the grinds had moved slightly.
                              The pour was much more stable though and held together longer than before.
                              Reading online it seems 16-18g is the sweet spot, so I might play around in that range to see if I can improve things better.
                              I pulled a couple of shots this morning and just stuck to the 18g dose and varied the grind to get it pouring ~36g in 25-30s. Maybe I'll dose down slightly until there is no hint of contact with the hex head bolt prior to extraction.
                              I think the puck is much better than before. There are two small holes on the right hand side near the lug, but overall I think it is an improvement.
                              https://photos.app.goo.gl/ifFSKGcVvlQcQtr92
