My musica is back together, but no hot water from the hot tap. It has a 2way solenoid running it.
The coil is fine and working from the ecu.
I pull apart the plunger and clean it up and it works correctly once or twice, then jams shut. Will not open even with a tap tap...
I have sanded the plunger and cleaned up the plunger bore, but it still wont consistently open.
It seems crazily simple, but this thing is the spawn of satan himself.
The plunger is a little scored up on its sides and the face is a bit chipped. But the viton seal is ok.
The piston seems to be jamming in the bottom of the bore. Like water is hydraulicing- locking the piston closed...
Any ideas...before i replace it.
