I use my expresso machine first thing in the morning then not again until around lunchtime. Should I leave it switched on all morning?
On/Off
Why would you? Most will likely switch off after a period of time anyway. But considering most machines take all of 5 min to get to temp, why would you waste the power?Originally posted by Australis View PostI use my expresso machine first thing in the morning then not again until around lunchtime. Should I leave it switched on all morning?
Australis why not consider a wifi connected timer? Some machines take half an hour or more to get up to temp, with a timer you can set a time or control remotely. If you mention the machine I am sure someone would be able to give an idea of warm up time.
Absolutely mean them. Without knowing what the OP has, my first thought was entry level consumer which mostly have an automatic shutoff and and small boilers that heat up pretty quickly.Originally posted by saeco_user View Postwasn't sure if you meant the comments above or they were written in jest.
and group heads that usually don't. Also, if it did fully heat in five minutes then I doubt Australis would be bothering with the question.Originally posted by drwharris View Post... and small boilers that heat up pretty quickly.
