If Peter Foster is involved with this steer clear!
Notice how all these weird and wonderful slimming products must be used with a caloirie controlled diet? Maybe that is what is really causing the weight loss.
It helps in weight control when taken in conjunction with a balanced (calorie) controlled diet and exercise.
The great thing is that if you have a balanced diet and regular exercise then any inclusion of coffee will help weight loss. Thermogenisis and what-not. Plus Id much rather be drinking my home roasted blends than what appears to be a sachet of preground geen beans. *yuck*
I could have saved all that expense on a corretto, popper Machine and grinder - I dont think :P
Whilst the taste of raw beans is sweet it doesnt have the same effect as freshly roasted beans. I will stick with brown beans and use the green for roasting.
I dont mind be on the larger size of normal ;D ;D ;D
