Im writing this to outline the hazards associated with buying a heavy 15kg plus coffee machine from a supplier who is not local. In my case I purchased a Makin from Victoria when I live in Newcastle, NSW. Unless the supplier has a local arrangement with warranty repairs the hassle and potential for damage having the machine shipped back and forth is not worth the effort. In my case the machine died within a months and I had to post it back to Melbourne. It got fixed and was returned without incident. Two months later the machine kept tripping the safety circuit in my house. I sent it back and was told that there was nothing wrong with it and that I needed an electrician to fix the wiring in my house... ( my home is 2 years old and I did say it was tripping the circuit breaker rather than the safety switch). As the supplier could find nothing wrong with it I was charged the $40 return freight fee. He advised me he had tried it at 2 premises and neither circuit breaker was tripped. I purchased it from Coffee Talk. It arrived back with a bent top and a small bulge in the side wall where something has moved due to rough handling in freighting. After much frustration I found a local repair shop in Newcastle who pulled it together and identified that as the boiler heated up the pressure valve at the top ( which are not good quality he told me) was spitting out about a teaspoon of water which was running over the boiler and onto the electricals which are located underneath on a lot of Gp 1 machines. He drilled a hole in the bottom of an aluminium film container, and replaced the pressure valve which I though was a unique repair job. It cost me $100 but Im back enjoying coffee and I wont be buying another machine from a supplier that lives any more than a 2-3 hour drive away at most... i.e. Sydney.
Buy Local...its worth it in the long run with the weight of these things to protect your investment.
Adam Ant
Adam Ant
