That bit of espresso that drips out after stopping the shot
  • That bit of espresso that drips out after stopping the shot
    This question has been bugging me for a while -- when aiming for consistent shots, how do people account for that gram or two of coffee that comes out after replacing the lever and stopping the shot?
    When dialing in a new bean I aim for a grind size that yields 2:1 loosely around 30 seconds. From there I adjust yield to taste and dial in the grind further to optimise extraction, again to taste but aiming for a reasonable shot time.
    So let's say you're shooting for 32g out for a given dose, do you stop the pump at 29g then leave the cup until the extra 3g drips out, or are those extra drips not delivered under pressure and extract differently? Do those extra few seconds of dripping 'count' towards extraction time? Sometimes I've had quite a lot drip out after the pump stops on an otherwise well-timed shot, maybe due to channeling towards the end of extraction.
    Of course what matters is how the shot tastes, but when making shots for others I really do have to brew by numbers and hope that what I'm sending out tastes good -- curious to see what others think?
    Is this with a spouted portafilter?
      If it ends up in the cup it counts.
      Java "Easy answer" phile
      Toys! I must have new toys!!!
        Yep spouted portafilter, a Lelit one which has the spouts coming out parallel rather than opposite.
          Then the drips are likely already extracted the same as everything else. If you’ve seen an extraction with a bottomless portafilter you’ll notice that as soon as the pressure is relieved, the flow ceases. Therefore, the drips you are seeing are just espresso taking it’s time to make it’s way through the spout.
            I was going to make a wisecrack that the machine may be in need of a prostate check. But I decided against it.
              Likewise
              • prh
                prh commented
                Editing a comment
                Great minds! Or something...
