You could buy 10 Behmor Brazen Brewers and produce 50 coffees every 10 minutes, 300 coffees per hour!
(which is what the below Golden Bean Setup was)
1 Litre of coffee every 10 minutes per brewer = 5 x 8oz cups (with enough room for a splash of milk). The insulated carafes hold it hot for more than half an hour so you could start brewing earlier than needed to have the volume ready. With some extra carafes and 3 Brazens you could do near 50 coffees in half an hour.
I also own a couple of airpot brewers and half a dozen airpots. Which can produce a large amount of coffee in a short time and have been used for many competitions including the Australian Cup Tasting Championships.
These are getting hard to find in AU voltage but will still be available and the Airpots are readily available locally still.
(picture is an example, ignore the brand, they all come out of the same factory I expect)
You simply can't beat good filter coffee for a crowd.
