Blonding point
  • Blonding point
    When pouring a shot, how do you determine the Blonding point. Seems arbitrary to me.
    Using a naked portafilter and a mirror.
    It is obvious when you see it.
      You could argue that it's arbitrary, but what it definitely is is both subjective and inconsistent. If you have no other way to monitor your shot it can sometimes be worth checking, but it's generally been discounted these days as having any real value. You're better off using time and volume as the parameters you measure if you can't weigh your yield then using your taste buds to direct you one way or another. When most espresso roasts were somewhat similar 15-20 years ago there's a possibility it may have been more consistent but the move to lighter roasts has made the old blond Ing point obsolete.
        naked portafilter shots are waaayyyy too mesmerising!
        I usually miss that blonding point!
        • Rami
          Rami commented
          Editing a comment
          Yep. Hence the question. Or I get nervous that I will miss it and cut the shot short
        • Micoffee
          Micoffee commented
          Editing a comment
          I've had similar looking shots as far as blonding/zebra striping/whatever other visual imagery people use, but different tastes.
          I generally now just go for volume out as my guide. Providing the shot went well (no squirts, etc) I usually get the shot taste I'm happy with!
          If you do cut it short, you're probably only getting all the good stuff anyway!
        • Micoffee
          Micoffee commented
          Editing a comment
          Just to add,
          I've only been doing this for a few years and certainly not trying to sound like an expert!
          i don't have the experience to accurately interpret the visual aspects of a shot. I go by weight of grounds, time and volume out. That way I can simply enjoy the visuals of a naked shot!
          Ahh, life's simple pleasures!
        Yes it is very subjective. We have pods at work, I'll guestimate blonding plus rate of flow as you have nothing else to work with. Normally takes 3-4 pods to get 30mls.
        At home, it's dosage, extraction time and volume.
