Want to start home roasting: equipment advice
  • grimsby
    Re: Want to start home roasting: equipment advice
    Be worth reading site sponsor Greg Pullmans review of Hottop and Gene Cafe roasters on his Pullman Tampers website if you havent already seen it.
  • GregWormald
    I roast indoors with a Gene Cafe and am pleased with the results. It does need to sit under a working extractor fan or it sets off the smoke alarms.
    I can set up, roast, and tidy away in half an hour.
  • Shannon
    In that case you are probably going to have to look over on the left
    to some site sponsors who sell the non DIY roasting stuff (iroast, gene etc)
    Good luck with it - I am going to be trying the roasting thing too over the chrissy break.
  • chartres
    I would prefer to roast indoors and thats what I was planning on doing. However, if I must roast outdoors, I probably would be able to do this too.
    However, I would love to roast indoors regularly. I would also want to avoid messing with hardware myself if thats possible ;-)
  • reubster
    Ed
    There are lots of options [homespun and retail] available, many are not suited to indoor roasting due to the chaff created by the beans.
    Can you confirm you intend to roast indoors [it will narrow down the field of available options]?
    A guide to Popper Roasting http://coffeesnobs.com.au/YaBB.pl?num=1174699442
    All about the Corretto http://coffeesnobs.com.au/YaBB.pl?num=1154442377
  • LindaD
    Welcome Ed!
    All depends on your budget. Alot here started off with a popcorn popper and advanced to more serious roasting equipment.
    http://coffeesnobs.com.au/YaBB.pl?num=1219897283
    Try this link above ^^^, and a search in this forum will turn up some answers for you.
    Good Luck!
    -Linda
  • chartres
    started a topic Want to start home roasting: equipment advice
    Hi, guys!
    I will be moving into a bigger place with bigger kitchen soon. I decided that since I will have some space on the bench, I will start roasting at home. I am very excited about it. However, I dont know where to start. What do you recommend. I wouldnt want to splash big bucks on the roaster, unless I absolutely have to. However, when I start, I would want to focus more on the roasting and beans than on messing with equipment. Also I wouldnt want a temp solution which I will have to change in a year or so.
    What options (in terms of equipment) do we have, what would you recommend?
    Also, I have very little knowledge of the roasting process. Any links, reading how-tos that you can recommend for the beginner? I have been to home-barista.com and some other sites. I couldnt find one simple and comprehensive guide for a dummy.
    Ed
