Building my own roaster
  • shsdarwin
    Re: Building my own roaster
    Hi Maheel,
    The original idea I had was a flap at the back, but am also considering a flap like you get on the old RSL lucky barrel.
    cheers
    Seb
  • maheel
    Hey Seb welcome to CS
    Love the idea, i have been tinkering a bit and was thinking of trying something like your design.
    Have you worked out a way to dump the beans out quickly for cooling? Or are you just leaving the "high" end open and then just tipping them out? A hinged flap or trap door might work if you have not sorted it?
    I was thinking for mine along the idea of running the barrel on rollers or cogs on an angle like yours, gas heater under on angle. then you can just lift the barrel off as its not "attached" enclose the roaster in some sort of enclosure.
    keep us posted
  • shsdarwin
    Hi Andy,
    Thanks for your comments. Really impressed with the speed at which feedback is given on this site! The chaff is definitely something I need to sort out. The idea I had was to make small holes at the back of the drum (about 3 cm long and about mm wide) which will allow for the chaff to fall out, but not the beans themselves. From what I have seen in my current test device, the slight angle seems to make the chaff collect there, while the agitators keep the beans moving forward. Ill have a look how this goes, however, your suggestion may come in handy. Was thinking of having a small 12 volt fan (that can cope with the heat), which i could mount at the front of the device.
    Anyway, still a lot of thought needs to go into this one.
    cheers
    Seb
  • Andy
    ..ok... 404 errors are gone now but attaching images here means they stay in the thread and can be commented on easier.
    Great looking project and your first shots, while a tad dark, look like a pretty good espresso.
    I would suggest looking at an "upgrade" to move the chaff out in the middle of the roast. It might be a blast of air or similar (few seconds of a heatgun?) as roasting the beans without chaff removal might make your roasts overly smokey.
    Look forward to seeing the project develop.
  • Andy
    Originally posted by 43584354514247595E300 link=1254059161/3#3 date=1254060098
    ps: Can someone tell me why im listed as an EX Member when I try to check my posts?
    Prob something to do with your browser cookies. Try logging out of the forum and back in again (and/or deleting your cookies in the browser).
    PS: email me ( andy@ ) these types of queries as they can be easily missed as an off-topic post in the middle of a thread.
    Anyway
    back on topic....
    Welcome to CS. I love seeing people try new designs and variations but I keep getting 404 errors on the links in your post.
    You can attach the images to a post here by clicking on "attachments" below.
  • shsdarwin
    To answer your question kk , It roasts about 300 grams of coffee. Currently this one simply sits on top of the stove. I have just got a bigger drum (believe it or not, but it was lying on the side of the road on the Pacific Highway) its a perfect size for about 1.5kg, so my roaster is becoming a reality now. Im not the typical handyman but am getting there. I will post more photos when Ive started the bigger version, but have to build my daughter a desk first.
    Seb
  • Koffee_Kosmo
    cheers
    You probably need to be activated by the mods or post a min amount of posts
    Or something like that ??
  • Koffee_Kosmo
    Have a look my Hybrid TO design
    http://coffeesnobs.com.au/YaBB.pl?num=1228631426
    Its a long thread or click the WWW at the bottom of my post to view the Power Point Presentation
  • shsdarwin
    cheers
  • shsdarwin
    Yeah, I know the corretto. Have gone from pop corn popper to that (oh and the frying pan option), but the heatgun and other hot air roasters seem to not give as good a result as using a rotational drum heated by gas. I cant really specify what it is, but there is a definite difference. It must be the hot air blowing across the beans while roasting. Maybe Im a tad to picky?
  • Koffee_Kosmo
    Re: Buildihttp://coffeesnobs.com.au/Templates/Forum/default/email2.gifng my own roaster
    Hi and welcome Sebba
    Good to see another passionate home roaster
    Looks like a design of a Cyprian BBQ can roaster
    What volume can you roast with this design looks like 250gr at a guess
    If you want 500gr + batches you should consider some of the home built designs that have been developed right here on Coffee Snobs
    And they work well
    Eg Corretto ok KKTO
  • shsdarwin
    started a topic Building my own roaster
    Having experience with commercial roasters, (my wifes adopted parents have a coffee farm in the Byron hinterlands and do their own roasting in an old greek-built 15 kilo roaster. Theyve let me play with it!) I decided I am not happy to go the hot air roasting path. Im working on a small roaster thatll roast my coffee like a good commercial roaster, but in smaller quantities. I have already built a tiny concept version, which has, after an initial roast which was too dark, produced some very good roasts of great consistency with some very well developed flavours .
    Have a look at my postings on my blog. Im interested in feedback, hints and tips!
    http://www.sebbasblog.com/?p=204
    http://www.sebbasblog.com/?p=211
    http://www.sebbasblog.com/?p=219
