Bosch GHG 630DCE and GHG 600-3
  • Bosch GHG 630DCE and GHG 600-3
    Hi has anyone used these guns before? Im not sure which one to get and these are the only available ones that can be ordered in at my local store
    GHG 600-3 - HOT-AIR-GUN
    Part No. : 0 601 94A 050
    Power Input : 1600 W
    Temperature Range : 300°- 500°
    Airflow Rate : 240 / 450 L/min.
    Weight : 0.73 Kg
    Price: S$130
    GHG 630 DCE- HOT-AIR-GUN
    Part No. : 0 601 94C 704
    Power Input : 2000 W
    Temperature Range : 50°- 630° C
    Airflow Rate : 150 / 300 /500 L/min.
    Weight : 0.73 Kg
    Price: S$187
    And theres another Black & Decker KX2000 going for S$98.
    Black & Decker 240v Heat Gun
    Re: Bosch GHG 630DCE and GHG 600-3
    WOW! You definitely dont have the cheap options huh?
      yep. unless I go and shop at cash converters for some old heatgun, but I doubt theyd have anything
        Surely you could get one online. Or maybe a CSer could get you one from Bunnings or similar and ship it to you. Where are you located?
          Im picking the Bosch GHG 630 DCE up tonight at my Bunnings for about $100.
          Ill be happy to pick one up some time and ship it to you.
          *Edit* Didnt realise you were in Singapore
            A$100 is about S$130..and postage will be expensive, so no, it wont make sense
            but is the 630 DCE better? or would the 600-3 do?
              oooh Singapore haha, yeah that might make sense to just get one there.
                Great gun the Bosch  630DCE. There are a few CSers using this one. I love it. Well worth the couple of extra bikkies!
                  Yuo I agree
                  Having total control of the temperature is very useful.
                  I usually raise the gun to slow the temp rate between first crack and second crack and sometimes a tweak of +/- 10C gives the perfect rate rise.
                  Also, I use different settable temps as my starting point for roasts of different sizes or for different beans:
                  eg 460C for 300g and 480C for 400g for a particular bean
                  or
                  To get a slower profile for an African bean Id start with a lower temp.
                  The temp selectability is not critical but I like having the flexability.
                  Another vote for the 630
                    Hi amber...
                    Where you have the choice, Id always opt for the higher output model as this will give you a lot more options with regard to controlling your roast profiles. So disregarding any control pros or cons, itd be the 630DCE for me.... 8-)
                      thanks to all. I think i have enough yes votes to place my order for the 630 now
                        Hi amberosw, I have the 630 digital heat gun and its a great gun. But you should use a fan to blow the chaff away, if using a corretto. Also the gun will tend to drop in tempreture if it senses its being blocked or in a confined space, so the fan prevents this from happening.
