Finally, Ive got everything for my corretto. Set them all up, and had a go. BAD NEWS~~My first roast was not sucessful, but it is very even (one thing that im pleased of). The temperature went crazy, I couldnt control it at all. And i cracked my probe due to i forgot to remove it
. O well it still works, who cares.... Anyway, Ive got a couple of questions~~
My Setup:
Heat gun: Ryobi 2 heat EHG 2002
Tripod for adjusting the height of the heat gun.
Breadmaker: Palsonic PAB-3600 (Added switch, now can spin for a long time)
DMM: QM-1324
Roasted 300g of MT Bin549
My question is should i turn the heat gun to the highest heat setting? Thats what i did today. The temperature went up very quick. It reached over 100 degree within 4 mins. I tried to adjust the height, but the temperature kept increase very quick. What i think i did wrong was, I set the heat gun too close to the bean. But initially, I set the HG to its highest heat setting and I set it about 4cm above the edge of the breadmaker, the temperature increased very very slow. Then i lower it down to about the same height of the edge of the breadmaker, then the temperature started to go crazy. Then, I turned the heat of the HG down, the temperature dropped significantly. So i turned it back to the hightest heat, then the temperature went crazy. Any suggestion that i can improve?
Tony
. O well it still works, who cares.... Anyway, Ive got a couple of questions~~My Setup:
DMM: QM-1324
Tony
