How do you tie cloth bags?
  • How do you tie cloth bags?
    The 2.5kg bags are the ideal size, but the metal bag ties are a pain.
    Simple question - what do you use to tie the bags once into production? The metal ones dont seem to retie all that well.
    I could use cable ties but might risk nicking the bag when cutting them off at re-opening
    Re: How do you tie cloth bags?
    Hi Jac,
    Your local hardware store will be able to sell you some removable cable ties....
    2mcm
      I just tie a knot in it
        Hi Jac,
        You could try:
        A big clothes peg.
        A bulldog clip from the office.
        One of those paper covered wire ties that come with packs of garbage bin liner bags.
        Man in Black
          I reuse them. If you straighten it out as you pull it off it is easy to wind it back on again.
            Yep thats what I do as well
              Originally posted by 5F7B727271714B5F7B67797B140 link=1232567869/5#5 date=1232580694
              Ditto.
              Just takes a little practise at first.
                Thanks all
                  You could use the plastic coated wire that comes with kids toys, itsvery flexible & easily reuseable. I have some I can send to you if you have no luck elsewhere.
                    I havent given it a try yet, a) hadnt thought of it until I read this thread and b) Im still working on my starter pack, so havent opened my first 2.5kg bag of greens. But I think sacrificing a CS bag and cutting it into strips (trial and error here but maybe about 4cm wide) and doing a "knot and bow" to make re-opening easy. If the loop isnt long enough it can be cut to make a single layer of cloth.  There would be 10 ties made from one bag, cheap(free) reusable and environmentally friendly when totally US (unserviceable)
                      I reuse mine, a little while ago Andy had different bags with cotton ties sewed into them, these were great but probably cost a bit more.
                        I re-use the wire ties too..... As above, just take a bit of care removing them so that they end up more or less straight and then re-tie afterwards. What makes an easy tie when the wire ties are no longer flexible enough, is to grab some cheap cotton shoe-laces (gym boot type, sneakers, etc). They last an awful long time and as Coffee Mum suggested, they can be recycled when their use-by date has passed.
                          Now I hadnt thought of that ... and I do have some coffee brown ones ...
                            Use a millers knot, http://en.wikipedia.org/wiki/Bag_knot
                            works, is cheap, been around for a long time, John
                              That knot is normally used by truck drivers for tie down tarps
                              Easy to tie up tight but importantly easy to undo, it just takes a wriggle
