My Roast from the Popper
  • My Roast from the Popper
    Thought I would post up a pic of my home roast, finally got my DSLR so I can actually give it a little justice in the shot!
    Any comments would be appreciated, its about my 5th roast using the Cornelius popper but this ones seems to be more consistent than the first few.
    Edit: Just noticed this may not be in the correct area, sorry mods, please move it if needed.
    Re: My Roast from the Popper
    Its the right area
    Looks good to me
    Send it over and I will grind & drink it for you ;D
    No seriously its looks to be an even roast
      They look great, now how long can you wait to try em....im backing 2 days max, how long was your roast? looking good mate!
        Yeah two days is about right!
        Actually more like three, tomorrow morning theyll go in as Im running out of the last batch.
        The lot after this are a lot darker even though I did them for the same time, need to do more visual checks, time was 4:30sec.
        I really need to do a few more so I can let them rest a little longer but seeing as I have a brand new EM6910 Im probably going to have to supplement with some other sourced beans to give me time to get a decent amount up and going!
        Thanks for the comments guys.
          4:30 sounds pretty quick, probably would taste better if you could extend you roast time, but it is hard to do with a popper unless you mod it.
          For figuring the rest time, try after a 2 days, then 3, 4 etc, and see what the optimum rest time is. I an roasting mostly decaf, which seems to like between 2 to 6 days or so, but normal coffee will like a longer rest.
          Randy
            if youre able to roast outdoors that will draw out your roast times a bit, even get a desk fan flat out to get some airflow over the popper
            I currently roast in the kitchen with a fan blowing some of the chaff out the window and keeping the popper cool, I can get out to 8 mins SC without any mods
              I drink quite a bit of decaf. For some time I timed it to 4:20 in my popper, and then moved it up to 4:40. Much longer than this it would taste burnt - I dont know whether this is affected by the type of popper. I would wait two days before drinking it - I found it would taste pretty awful before this, and it also didnt last that long either - after 5 or 6 days it would be in steep decline. In the middle, though, it was very smooth, and I found it easier to roast than normal beans.
                They look great!...you should be very proud of them :P
                Dont forget to let us know how they turned out in the cup!
                  Originally posted by 626865666665686B646C6B090 link=1250940325/6#6 date=1251987987
                  I can extend my roasting time because I have my popper set up where I can adjust the heat with a variac.  If you cant adjust the heat then extending the time will just make them darker, and eventually burn the beans.
                  BTW, I have seen where people use a 100 foot extention cord to connect their poppers, to extend the roasting time.  A 100 foot cord will lower the voltage at the popper, which will lower its heat output, resulting in a longer roast.
                  Too short of a roasts will make the coffee brighter.
                  And the nice thing about decaf is no chaff. I have seen other people complain its hard to roast decaf, but I have not found that to be true. And decaf does have a small window where it tastes good, so home roasters have a big advantage when it comes to decaf.
                  Randy
                    Randy where are you situated?
                    The 100 foot cord voltage drop thing does not seem to happen in Australia.
                    If it does at all, I believe it may in the US.
                      Australian standards state that the drop in voltage shall not exceed 5% of supply voltage. It depends on the current to be carried in amps and the length of the route of the cable. It is true that the longer the cable, the greater the voltage drop will be. To overcome voltage drop over long distances larger diameter cables are used. As the load is quite small the drop in voltage will not be great, unless you use 100m+ long extension leads. Even so I doubt you will experience the effect described in the US.
                        I am in the US, and the people who have tried it are also probably in the US. I have not tried it, only saw stories on the net about it, but I can see how it could work, with enough wire you will get some voltage drop.
                        For Aussies, since it is 220V, there is less current for the same wattage, which would mean less drop (V=iR), so about 1/2 of the drop, so only 1/2 as effective as it would be here.
                        Randy
                          Id like to lengthen the roast time, as a lot of things get better with a longer roast time to bring out the flavours so I am actually looking into the corretto method. Getting the breadmaker next weekend!
                          A mate actually reckons a dimmer switch would be ideal to use to lengthen the roast times if I wanted to continue with the popper.
                          The coffee is coming out good but I dare say not the best to what it could be, but mind you I have a machine Im still learning, a whole craft Im still learning and that gives me lots of room for improvement, and the only way is to practice practice practice!!
                            Is he an electrician or electronics expert?
                            If not, I think you might find its not that simple.
                              Originally posted by 7F435E454F4E594C444F2B0 link=1250940325/13#13 date=1252133305
                              TG is 100% correct... A dimmer is not a device to control anything - other than lights..
